Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Freezer stoped two days ago!
My freezer has been un pluged for two days! the food is stillvery cold but not frozen?// can i refreez???
  • Kenmore Master
  • 4,655 Answers
Sears uses a nuber like this 213.25647 Can you find a number like that so I can help you?
Posted on Jun 19, 2009
  • John Tripp
    John Tripp Jun 19, 2009
    Sorry I answered your question with a question, I was very tired and when I see no model number I ask this question. As for the food? Most foods in the fresh food section normally survive 37 to 42 degrees for more than a week. If you wanted me to help you repair your refrigerator I could answer that. As for refreezing, I would try to salvage the food if it were mine and did not reach dangerous levels of spoilage temperatures. Sea Breeze
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
I have a Conia fridge/freezer. The freezer is working fine but the fridge part is not getting cold at all.
In some cases like you have, you need to unplug the unit and let it thaw out. Store you freezer food in an ice chest or else where to keep it frozen.
If the unit has self defrost, the defrost cycle refreezes and blocks the circulation of the refrig area. Make sure all frost and water are removed before plugging the unit back in.
Mike
Jul 29, 2009 | Televison & Video
Top freezer food gets freezer burn fast and now ice cubes and ice
Your discribing 2 opposite symptoms. But 1 thing may be causing both. first thing I think of is a defective defrost heater safety switch. It allowes the food -and freezer compartment to become too warm during defrost. This allowes the food to un freeze. then when defrost is terminated the temp goes back under freezing til the next defrost. 3 to 5 cycles like this and yes you could ahve freezer burn and icecream melting. DOes the ice cream refreeze too? If so you have to remove the freezer pannel covering the evaporastor coil inside the freezer. Locate the defrost safety.
1 of 3 kinds 2 opf these are b8-metal switches and are round and of these 2 kinds 1 is about nickel size and the other is about quarter size and both are round and can be attached to the coil tubing or the freezer wall. Usually these 2 kinds are on Refg/Freezers with no electronics on the door or thermostat.
If you have an Led or LCD display you ahve electronic controls and in most cases have an electronic thermisitor about 1" long and 1/4 to 3/8 inch dia and insulated and attached to the freezer coil line leaving the freezer or on one of the U bends of the coil. It may be attached with a plastic wire tie. (The tie could be broken but this is doubtful from discription).
1st freezer burn is usually caused by drying out of the food while still frozen. And this is why your case is so interesting by doing it so quickly. In all cases 1 the food is not in air tight containers. And the water in the food is being drawn out of it.
May 08, 2009 | Electrolux Refrigerators
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
