Question about Cooktops
Increase btu output on jenn air svd48600
How to increase btu output on jenn air svd48600
2 Suggested Answers
SOURCE: Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Posted on Sep 08, 2008
Flame size will not regulate. Authorized Jenn-Air repairman came out and replaced the regulator and I still have inconsistent flame size on all four burners. About 1/2 the time it's like it's...
What other appliances work on gas? The furnace? The water heater? A gas dryer? How much propane is in the tank? I wonder how the cooktop would work on a seperate tank? If it worked perfect on another tank I would say you have a plumbing problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 26, 2011 | Jenn-Air JGC8536 Gas Cooktop
Jenn-air cm200 fan switch replacement part number?
Here is the part number for the switch 74009254
May 08, 2010 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Is 8000 btu.burner enough heat for general use
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
Feb 03, 2010 | Jenn-Air JGD8130 Gas Cooktop
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn Air cooktop JGD8130ADS - Propane to Natural Gas
propane has more BTU, so has a small hole, NG has a laeger hole, when i last called a plumber, all he did was remove them and drill a larger hole...i don't know what the hole size was, but thats what he did. hope this helps
Jan 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JGD8130
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Cooktops Logo
102 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
