Question about Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
How to hook up steering wheel controls ouku car stereo
2 Suggested Answers
davis_keith1
SOURCE: Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Posted on Mar 01, 2013
What do I need to connect a Sony DAB 500a stereo to my C4 Grand Picasso, 13 plate, to allow steering wheel control?
Not possible, the steering wheel controls will only work with manufacturer original fit stereos!
Sep 06, 2016 | Citroen Cars & Trucks
Installation instruction
what vehicle are you putting it in, as if it was meant to be in the vehicle the wiring would be there already , if not forget it to much work and not much chance of getting it working properly anyway
Jun 01, 2015 | Ouku Double 2 Din Indash 7-Inch 2002 03 04...
What wire runs steering wheel controls on a 2500 gmc sierra
This is not a question for JVC but more for GMC. On the JVC radio side, if it can be controlled via steering wheel, you will see a blue with yellow stripe cable that states [STEERING WHEEL]. Not all radios can adapt to steering wheels controls.
Aug 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Need user manual for " HD LCD In Dash 2 Din Car Radio DVD Player Video Stereo GPS Navigation Navigator Bluetooth Ipod TV Radio Steering Wheel MP3/4
Model numbers and manufacturer are instrumental in solving these questions. Without them, we can't help.
Sep 23, 2013 | Ouku Toys
Why does my ouku keep draining my car battery
Salvatore, I have been piling my hair out!!
How are ya? I have the same problem in my 2004 Buick Lesabre Custom 3.8. I had been slowing installing (over weeks - drove around with an open dash). When I started having battery problems, I had just connected the bus wire (pink?) from the Ouku to the harness. Also, things started acting weird such as the right window worked intermittently? Also, I have a two modules I haven't hooked up yet (axxcess ASWC steering control and a GMRC-04 chime retention).I could not get the Ouku to read my steering controls. So those are not hooked up to the bus wire. That's next. I am going to disconnect the bus wire and see what happens. 'bus wire' or "data line" pertains to the computer and it's signals. Bus wire = 5V - don't hook it up to 12V. Lakewood Ohio David. If I am wrong somebody jump in and help!!
Jan 24, 2013 | Crown Ouku 7" Double 2 Din In Dash Car Cd...
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
2001 nissan pathfinder se wiring diagram
I have a 2001 Nissan pathfinder and had the stereo changed. The original stereo had the feature of the controls on the steering wheel but when the stereo was changed that feature no longer worked. I had brought the car to a shop where they installed that stereo and the controls were not working but I didn't want to bring it back to them. I now have a Sony Stereo in it now and would like to get the controls on the steering wheel working again. Could you please tell me which wires are the ones that connect the steering wheel controls to the stereo.
Mar 04, 2012 | Cars & Trucks
I put an aftermarket cd playeer in my 01 chevy blazer. On the steering wheel there are volume controls etc. The wires do not hook into the new stereo. how do i hook these wire into the new stereo when it...
in order to use the streering wheel controls you have to have a stereo with a remote control. you can the purchase a part that will connect to your steering wheel controls and send a signal to your stereo. i do not know what the name of the part it is, but if you check with a local electronics store I'm sure they can help you.
Jun 09, 2009 | 2001 Chevrolet Blazer
Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera Logo
43 people viewed this question
Top Crown Car Audio & Video Experts
Dennis Key
Dennis Key
Lawrence Oravetz
John
John
Are you a Crown Car Audio and Video Expert? Answer questions, earn points and help others
