Question about Hardware & Accessories
How to connect cls q 31 d - Hardware & Accessories
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How to program CLS Q 31 D TIMER
CLS Q 31 D timer is ordinary 50-60 Hz 24-hour din-rail analog timer; rated 15 amp, operating voltage 230v with power reserve and 30 minute time increments.
15 amp safe max is 12 amp x 230V = 2760 watts. Use line fuse to protect timer from overload. Use contactor for heavy-amp loads and 3-phase loads.
Copy following links for setting analog timers and wiring din rail timers
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Add a comment and describe application for this timer
May 18, 2013 | Hardware & Accessories
What are the frequencies for a motorola cls 1410 radio
Here's a link to the user guide for the CLS model radios. You will find the frequency list on pages 39-41.
http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Best regards.
Aug 04, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How to change frequency on the cls 1410
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find basic programming instructions on page 28.
Best regards.
Apr 19, 2010 | Motorola CLS 1410 (4 Channels) 2-Way Radio
CLS Release?
CLS info:
http://www.mbusa.com/brand/models/CLS500C.jsp
May 14, 2008 | 2008 Mercedes-Benz Mercedes Benz Cls Class
User's guide
A User's Manual for Motorola CLS series is available online here.
It's file name is Motorola CLS Manual (PDF).
You would need Adobe® Reader® to view PDFs.
Good luck and kind regards.
Dec 29, 2007 | Radio Communications
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
