Question about Black & Decker Blenders
Quit working blender - Black & Decker Blenders
Ninja proffessional bl660 blender single serve not working but regular blender is
That is not SUBTLE...!!!
Go with the REAL BLENDER... I've never heard so much
horrible complaints... even from RALPH NADER...
(In my very humble opinion)...
Where there's complaints (tons of them)..
There's trouble.
The whining about ninja's here is quite amazing!!
Jan 31, 2014 | NINJA Blender with Single Serve Accs BL660
I need a replacement viking blender blade (648204)
I found something on amazon, click here and take a look, it might be helpful: Amazon com viking blender blade. Cheers
Dec 02, 2012 | Viking Blenders
My blender is model# KSB5 & it works fine; the problem is the 'jar' is stuck onto the unit. I cannot remove the canister no matter how hard I try. Help?
This is a most unusual case, under the circumstances I would contact KitchenAid for a solution, have you tried turning canister clockwise and anticlockwise, should unlock in "anticlockwise position" if no luck contact the manufacture.
Mar 31, 2012 | KitchenAid KSB5 Professional Stainless...
I was using my blender and stopped to add more ice for a smoothy mix, but when I tried to start it up again the lights began flashing at random but the blender would not work. Why?
It sounds like it may have overheated. Firstly, Switch it off and let it cool down for a few hours. Quite often it will burst back into life. If not, you will probably need a new control board. These come in several variations:
9708845 Silver 110v 9709339 Black 110v W10291857 Silver 240v
Mar 25, 2011 | KitchenAid KSB560 5 Speed Blender
Blender motor quit working
there are really only two options. 1- you can try to find out if the manufacture has a department in your area and weather they sell replacement parts or if not then you can take the motor to a re winder they re wind the burned out wire and replace it with new but it can be expensive but they are really your only options.
hope this helps
Jul 12, 2010 | Cuisinart CB-600 Blender
Replacement jar for a GE Insta Blend 14
Many blenders will work with a standard canning jar (pint or quart) I'm not sure if that will work for you, but it's a definite cheap fix.
Nov 20, 2009 | Back to Basics Blender Solution 5500...
Blender died ...... motor won't turn on
Have you tried the fuse first....
If it is the motor (quite rare), these people may be able to order you one:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Aug 10, 2009 | KitchenAid KSB3 Classic Work Top Blender
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Blenders Logo
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
