Question about Juki DDL-8700
Why my juki ddl-555-5, wheneve I turn on the power switch, just run split second then it automatically turns off?
My Juki DDL-555-5, was damage on the wire the plugs into the wall power outlet. I had connected and wrapped it with electrical tape, this was last January. At first, whenever I turn on, just split second it automatically shut off. The I loosen the electrical tape wrapped on the wire, it then worked. I had used it until today, not it suddenly shuts off automatically. Same issue like before is happening. What I did is just cut off from the damage part that was wrapped with electrical tape then this part of the wire I connect this to power switch(on & off of the machine). I had put the clip like it was before. But still shutting off automatically. What is wrong with my machine?
  • 2 more comments
  • West Zegarzewski Apr 24, 2017
    Buy new plug tip for wire could be damaged tip if not could be frayed or damaged wire under coating and both sides of outlet are always hit its the equipment that directs the flow of current if not wire or plug tip its the coil inside the machine
    Both of outlet are always hot i meant
  • Joseph Coppeto
    Joseph Coppeto Apr 28, 2017
    I think the frayed cables that were taped could possibly be touching and casing s short. This can cause a shut down if the unit has such over current protection. If this plug goes direct into a wall it is alternating current AC
    not from a Ac to D.C. Converter type power supply and cannot be accidentally reversed.
  • electronic & computer repair&  servicre
    Take this unit straight to an authorised repair centre. STOP using it as it could be dangerous if mains powered. The repair should be minimal cost, indeed it may just require a new lead? Do it properly n fix it once n for all safety is all important.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Try swaping the wires that you cut you might have them backward.if that don't doit you might try changing the hole cord to a new one .
Posted on Apr 02, 2017
  • Edward Shelton
    Edward Shelton May 08, 2017
    Never heard of AC being wired backwards. Something to think about.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Get a new cord.never rewire things you know nothing about.plus if item is computerized in anyway.you are corrupting the electronic brain with uneven current.and its just not safe.A FIRE HAZZARD
Posted on Apr 05, 2017
    Well done Casey r. Safety first. Always. Never ever "play" with Mains power it can b fatal always check polarity n earthing. Get a professional to at least check it out. Many kind ones may even do it gratis?
  • 25 Answers
Sounds like the hot wire and the neutral are touching, each wire has to be taped separately , for instance if there is a black wire and a white wire you connect black to black and wrap with electrical tape then connect white to white and wrap with tape till no wire shows and when you pinch it between your fingers no wire pokes through. Then you can tape the two together. Do NOT do any of this with it plugged in! I would really like a pic of your cord so that I could give you a better assessment .
Posted on Apr 20, 2017
  • 54 Answers
Either you have dead short the wiring with your fix or you may be overloading the circuit. It should be 20 amp. Is your circuit breaker popping. Are you resetting the breaker? Change the plug. Electricity is like water. If it get's blocked it stops working.
Posted on Apr 18, 2017
    Problem Solver:
  • 11 Answers
Replace the whole wire from the switch to the wall outlet. Black is hot wire, white is neutral, and green is the ground.
Posted on May 01, 2017
    Problem Solver:
  • 24 Answers
First be sure that on/off switch not damage then that your electrical connection are correct and secure, also check the light connection and switch if applicable last check in the owners manual the lubrication points and proceed,
Posted on Apr 28, 2017
  • 84 Answers
Your safety switch may be defective. The constant over heating in the original wire may have damaged the safety switch.
Posted on Apr 25, 2017
  • 3 Answers
Posted on Apr 15, 2017
    Habit-Forming:
  • 75 Answers
Open where the electric tape insulated put make good by taking extra wire from insulation fasten the connection
Posted on Apr 10, 2017
If it is a clutch motor check load .....motor most probally 2 phasing.
Posted on Apr 06, 2017
2 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Juki ddl 555 lock
Does this look like your machine?
JUKI DDL 5550N Manuals
Jul 07, 2014 | Juki Sewing Machines
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
What type of oil is need fro juki ddl-555
hi there
you can use juki deffrix oil no.1 or in your local market light and clear oil for industerial sewing machine
May 22, 2010 | Juki DDL-8300
What needle type is used for the juki ddl 555?
I use Organ needle in mine. You can find these at most dealer who carry industrial parts, including ebay.
May 11, 2010 | Juki DDL-8300
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
Mar 18, 2010 | Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Juki DDL-8700 Logo
160 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
