Question about Nordic Track T5ZI Treadmill Walking Deck
Incline settings reversed
Inclines when trying to decline and vice versa
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
The wires for the incline motor are reversed on the board.if you follow the wires you should have 2 that look identical. reverse where they connect on the board and see .
Posted on Apr 20, 2014
2 Suggested Answers
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
When I set machine on cold wash the water is hot and vice versa. How can I fix this?
reverse the water supply hoses either on the wall or on the machine. be sure to turn off water valves first. or just wash hots in cold etc. :-)
Apr 05, 2015 | Fisher and Paykel Washing Machines
Inclines down, declines up
The unit has likely been disassembled and put back together incorrectly. The incline/decline motor runs on direct current, and reversing the polarity of the terminals on this motor will cause this exact problem. If it has not ever been serviced, I would look on the manufactures website for a software update, or fix.
Apr 18, 2014 | Exercise & Fitness
Not incline or declining
I expect there is a limiter switch that tells the treadmill when it has reached its maximum elevation. The switch is probably either malfunctioning or broke.
Feb 27, 2014 | Nordic Track Exercise & Fitness
My tractor won't go up any grade or incline.... it just gets slower and slower until it stiops.
HI
Im sure you have a hydrostatic or an automatic forward and reverse right well your ****** is on its way out when it warms up it likes to crawl in this case even if you attempt to check oil or even try draining and putting in different oil its a tough one ****** is expensive
Joe
Joe
Sep 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
My treadmil inclines and declines repeatedly. It will not stop unless I unplug it or take the key off.
you could unplug the wire for the incline motor take hood off. look for the wire that connects to the incline port and remove. it will say incline mtr this will at least let you use it
Mar 06, 2011 | Proform Exercise & Fitness
My proform tl 585 is stuck on an incline. when i try to lower the incline, the button does nothing. the incline could still raise, but obviously i'd rather lower it than raise it more.
Take the cover off and inspect the wiring. Make sure all the wires from the incline motor are connected.
If all the wires are connected and everything looks OK, try the incline again.
There are only 3 wires on the incline motor, red, white and black. This machine does not rely on any electronics to operate the incline. We know the motor works, because it will go up..Likely the switch in the console is defective.
To lower the incline, reverse the black and red wires, that will make up go down and vice versa.. If that doesn't work, the motor is likely defective.
The incline motor is available, around $110. To order find the model number on the frame of the treadmill and call the service number found there. Have your model number ready (starts with "P").
The console is no longer available.
Feb 27, 2011 | Proform 585 CS Treadmill
Same exact thing
The incline is trying to calibrate if you let it do it till it is done it should stop. If it continually trys to incline every time you use it there is a incline sensor out of position or the console is bad.
Jul 26, 2009 | Exercise & Fitness
Nordic Track T5ZI Treadmill Walking Deck Logo
117 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
