Question about RCA F27669 TV
RCA 32648 i dropped this tv isthere any common things that could be repaired to bring some life to this tv
  • RCA Master
  • 1,229 Answers
If you dropped your TV I really doubt if it can be repaired. The board contains many miniscule traces that are to difficult to fix. And just maybe the picture tube has internal damage, if not the neck of the tube is broken. Donate it to tv repair shop for proper disposal. In the MOURNING you can shop for a new one!!!!!!!!
Posted on Aug 04, 2009
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
My RCA 46 LCD has no picture or sound but the blue lights on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 02, 2015 | RCA Televison & Video
I have a Denon AVR 888, I want to use the reciever for my audio coming from my TV, I have plugged in a HDMI into the in port and connected it to my TV, I do not get any audio from the reciever
HI,
If you want to get the audio of tv program through the AVR then your tv should have a HDMI out port. Because you have connected the cable directly to tv. You didnt mentioned anything about your tv (make and model number). So its not possible to give you a final answer.
Check on thing isthere ia nsy RCA audio output in your tv. All tvs will have RCA audio out put. Wich you can connct to the TV /CBL in put of your AVR using a RCA cable. Then select the TV/CBL Using the SOURCE SELECTOR on the frond of the AVR.
Another Way is if there is optical out put on your tv then you can connect the optical out to the AVR's OPTICAL IN 1 or 2 Using an optical cable. Then you have to got to the input assignment menu of
the AVR and then you have to assign the optical 1 or optical 2 to wich you have made the connection. Here i have added the link to the user manual of the AVR. Check the page number 22. Which shows the menu tree. To assign the optical input for TV/CBL you have to go to the Input set-up there you will find the ASSIGN on the under CD,AUX etc menu.
This setup required if you use OPTICAL input of the AVR. Check the page number 14 for the connection diagram.
IF you are going to use RCA cable the simply connect one end of the rca to TV's AUDIO OUT and other end to the TV/CBL input of the AVR. And then select TV/CBL.
Here i have added the picture of RCA cable that you nee for making such connection between TV and AVR.
USER MANUAL
Ajin
Apr 26, 2012 | Audio Players & Recorders
My tv wont turn on
This is a common issue with this model. They used cheap components in the power supply board and these cheap capacitors fail and keep the unit from powering up. It is an easy repair to replace the bad capacitors with better quality parts and this should bring the unit back to life. Here is a repair guide for this model that shows what to look for and replace on the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Aug 29, 2011 | Polaroid TLA-01911C TV
I need a power supply board for this tv RCA does not sale this power supply board any more
wow, good luck with this one, many repair shops end up with these tv's and the owners don't want to bother with them when they find out how much it will cost to fix them. that being said, get on the phone and call a few and you may find just what you need, another alternative is of course the internet (try sears parts store), or Ebay, hope this helps. I like you fix old stuff and enjoy bringing things back to life. good luck
Mar 10, 2011 | RCA HD52W56 52" Rear Projection HDTV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
RCA P60920BL wont power up makes clicking sound
This is a chassis PTK195 and acommon fault with these sets, that causes the symptom you describe, is the flyback transformer goes bad.
If you're at all familiar with electronic repair you could start checking there (and horizontal output transistor shorts). If not have an RCA approved warrany repairer give you an estimate/service call.
Note: the good thing about these sets is the chassis is very common and easily removed for service (without bringing in the whole set.) .
Usual cost to repair flyback/ dead set symptoms $200-$350.
Nov 24, 2009 | RCA P60920BL 60" Rear Projection...
52" RCA HDTV projection TV 4 years old and just started getting
This unit needs repair your convergence needs alignment, which with the RCA model needs to be done by a tech and the Blue card is either dead or is dying. You need to take it in and evaluate weather or not it is worth repairing or just wpending the money on a new T.V. - You can expect to pay around $350 - $800 to get this repaired, plus pick up and drop off. I would not endevor to do this myself as there are other things that can be damaged when messing with it.
Dec 08, 2008 | RCA D52W23 52" HDTV CRT TV
Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
RCA F32650 32'' TV Just stopped working and 3 months after warranty 3-yr warranty expired
This is a very common problem with RCA tV sets. But unfortanatly, RCA is no longer made in this country or even owned by RCA anymore. They are a Canadian company called Thompson Corp and could not give two hoots about any problems with TV sets sold here in america. I say this from experience and try to contact them and file a complaint. ther customer service is rude and basicly calls us idiots! Alot of class action suits are pending or have been dropped as for the amount of sets they company have sold,They have attorneys working for them and delaying the cases. It is really the fault of the US Judges that are total morons about these things and try to go by un written laws. They dont have a clue as most of the US goverment does not. Your problem is not a power supply problem, But a high voltage transformer and a horizontal output transistor, and the reason why the estimate was so high, is because the tranformer is no longer available. Thats why the estimate is so high. Because who in there right mind would spend so much on a set as this. You can buy a 32" RCA(BUT I WOULD NOT BUY TRASH)At Wally World for less the $250.00 bucks! I no longer accept RCA TVs in for repair as replacement parts are so much money and im not proud to say I work on RCA TV sets. Total garbage sets!!
Oct 07, 2006 | RCA F32650 32" TV
RCA F27669 TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
