Utstarcom wa3002g4 all the leds including power led is blinking continuously if switched on and no connection is made
  • 57 Answers
SOURCE: there is no connection with my router ADSL SMC7404WBRA
Did you call your ISP? If the data is not ok, i think the problem is in your Internet Service Provider..
Posted on Nov 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
mbase213
  • 728 Answers
SOURCE: Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Posted on Apr 25, 2009
SOURCE: NOkia seimens hardware problem
1.check out whether you are using the same adapter provided with the modem, if not sure check the voltage rating details provided on the modem as well as the adapter.
2.try to reset the modem by pressing the rst point provided at back side of modem keeping the modem in on condition. keep the reset s/w pressed till you see the modem lights turning off and again turning on.
3.if the lights light up normally you have the configure the modem.
4.if still having problem contact me on 9444482052 ........jammy
Posted on May 19, 2009
SOURCE: My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Posted on Jul 24, 2009
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Samsung UA50F5500 50" LED TV does not want to switch on. Remote receiver LED flashing all the time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Feb 16, 2015 | Samsung Televison & Video
Why does the LED light continually blink and not go in to standby mode?
Continuous blinks of standby LED indicates a main board fault. Just check this set after a reset. If it do not help you, replace the main board.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
DSL NOT STANDING.
If you are having trouble with the modem, call your isp to get this trouble sorted out.
Apr 20, 2014 | Computers & Internet
My modem is connecting problem,it will connect after five minits it will disconnect. modem model:utstarcom-wa3002g4
I have a link about how to configure it to Always On mode with ADSL as the connection technology from the ISP.
http://www.indiabroadband.net/bsnl-broadband/4545-configuring-utstarcom-wa3002g4.html
If you are using other technology there might be difference on the settings. You can contact your ISP to find out the technology they are using which your modem connects to. You can apply for an additional IP address to improve the performance of your connection too. Make sure you have a filter on every phone line if you are sharing the phone jack with your ADSL connection. Most of time they should have done that when they install the ADSL but just in case.
Aug 18, 2010 | Computers & Internet
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Jul 08, 2009 | Computers & Internet
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Computers & Internet Logo
David Payne
David Payne
