Question about Behringer Music
How to hook a pmp6000 and a EP2000 up
How do i hook the PMP6000 and the EP2000 together
sparky1500
  • 1066 Answers
SOURCE: i just both the Europower pmp6000 powerd mixer and
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Posted on Nov 06, 2010
  • 5603 Answers
SOURCE: My pmp6000 wont work in
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Posted on Dec 03, 2010
  • 5603 Answers
SOURCE: how do i hook up
You have to make a choice... you can tie two main speakers to the "B" channel and the two monitor speakers to the "A" channel.
The speaker configuration slide switch is set to MON1/MONO. The main slider controls the volume of the mains and the MON1 slider controls the level of the monitors in conjuction with the rotary MON1 knobs for each channel.
Each output should not be loaded heavier than 4 ohms. This would be a max of two 8 ohm speakers for each output.
Posted on Dec 24, 2010
  • 5603 Answers
SOURCE: What is the bridge amp
In bridged mode, both sides are used to drive the same speaker. One side is phase inverted relative to the other so the two sides add their voltage. It is important to note that you cannot go below 8 ohm speaker in this mode. The amps can generate about 60volts peak or about 43 volts RMS. So the net will be about 86 volts between the two sides. With 86 volts on 8 ohms you can get about 925 Watts max... yeah it is not the claimed 1200, but it is a lot closer than the shop vacuums claiming 4Hp when running on 120 volts... Those are peak values that have LITTLE to do with actual true values.
You can't run stereo in this mode because BOTH sides are used as a single power source. The PAN controls will have little effect as the system is in monaural mode.
Posted on Mar 18, 2011
  • 5603 Answers
SOURCE: we have a pmp6000 mixer hooked up to our ep 4000
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Posted on Aug 06, 2011
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
Will my behringer pmp6000 work with out another amp to power it
Since it has its own amp built-in, I'm not sure I follow. Why would you "need" another amp to "power it?" Please be more specific. Thanks.
Jan 13, 2013 | Behringer Music
I have a behringer pmp6000 no sound
No sound at all, or just to the "r" (rear / right?) speaker? Can you be a bit more specific? Will be glad to help.
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
I have two B215 600 watts speakers. Smoke started to come out of one when it was in use. I continued to use the other one, and about an hour later, the bass on that quit working. Any help with...
Sorry, those speakers are rated at 250 Watts RMS continuous, NOT 600. The speakers are nominally 8 ohms. The PMP6000 will deliver about 250 watts RMS to an 8 ohm load so the speakers should be able to take this as long as you had one per side and NOT using bridged mode of the PMP6000. It is possible that you fried the amp, although the PMP amps have a speaker protection network that shorts the output should the amp hard over. It is strange that you could draw smoke with the setup. Hopefully you were not generating very low frequencies that were below what the speaker could handle OR that you did not crank up the bass with the EQ such that frequencies below the speakers rating were sent at high levels. Your speakers are rated for a low end at 55 HZ. You should have the eq cut the gain below that. The leftmost EQ (50 Hz) should NOT be higher than center... if you boost that one, you likely will be buying new speakers. If you need power below that, then you need to be using subwoofers. Hopefully you haven't damaged the PMP6000... I assume that was the amp you were using, although you haven't stated that. At this point, unless the stuff is under warranty, you nee to open the speakers and see what has blown... could be the woofers or the crossover network...Use an ohmmeter to check the woofer DC resistance... should be between 7 and 9 ohms. If it is open circuit, the voice coil is blown.
Sep 19, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
I have a pmp6000 powered mixer. I was running an ipod in and sending out to one powered speaker. I heard a loud pop and smoke started pouring out of the mixer. I immediately stopped using it. This morning...
Cease using the mixer until it is repaired. One or both of the amps have blown. Further use MAY result in power supply damage. 1 to 6 switching power transistors will have blown and often a Zener diode or two. If the metering resistors smoked, there will be two small surface mounted transistors per channel blown wide open as well. These are all in the HCA2400 amplifier module.
Feb 12, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
How do i hook up my jbl-jrx112m monitors to my pmp6000 so i can control sound volume,i have sound but only main control not monitors
Dec 24, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Music Logo
95 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
