Question about GE GSH25JFR Side by Side Refrigerator
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
First off it started dripping about 6 months ago just a little not enough to be a problem, put a cup there to catch what little did drip. About 2 weeks ago I had water pooling on the floor, discovered that ice maker had put out too much water and nearly whole freezer was iced over, coils down to bottom of freezer. Then I changed the whole house filter took filter off of fridge and put in another valve to shut the water off. That gave me about 4 days of no dripping.
Then it started dripping again so I closed down that valve to decrease the amount of flow to fridge, that worked for about 5 days of no dripping and now it has started in again. It appears that the ice maker is still holding it's own and not over filling when the water has been on or off HA HA. Seems like to me its a water valve issue. However you are the expert. Thank You for your time I greatly appreciate it.
Thanks
Heath
  • 6,784 Answers
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Posted on Jun 19, 2009
The water will stop for about a month then start up randomly for 6 months then stop again. GE side by side GSL25JFPBS
These models have a problem with the water line freezing in the door. Leave the light on in the water dispenser part to keep the line ice-free.
You might want to turn the freezer temp up a bit as well. Not sure whether food items resting against the door may have some impact on the problem.
Oct 23, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water drips from door door water access
Hi, it sounds like you have an inlet valve going bad. It is not sealing tight enough to stop the water pressure. Part # WR57X10032and is located below the refrigerator in the back. If you remove the tube that goes to the dispenser, you can probably see the water dripping from the valve.
Please let me know if this helps you. Let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JFRWW
Water line is frozen in freezer door. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 27, 2007 | GE GSH25JFPWW / GSH25JFPCC Side by Side...
GE GSH25JSRSS Stainless Steel
the water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
Nov 26, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't turn off
Stix: Check behind the dispenser handle the switch or button which is responsible to activate the mechanism of water dispensing. If the switch or button is covered with a reubber you must remove the rubber cap or whatever cover it has. If you have mineral oil or somekind of greasy stuff (vaseline or something similar) lubricate the switch or button. Open the freezer door and activate and deactivate the dispenser several times to lubricate the whole mechanism. SithPitt
Jul 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
372 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
