The power light wont turn off
The power light on my computer will not turn off, not long ago the power supply thing in it burnt out and we got a new one but ever since then the power light wont turn off.
    New Friend:
Does the PC turn off at all or just not the light. If it's just the power light on the tower, Check the connections between the tower to the motherboard and make sure they didn't get moved when the power supply got replaced.
Posted on Apr 18, 2014
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Won't turn on manually
The reason you DVD player wont show turn on a green or red light is simply because there is no power supply entering the player.
This could be as a result of the player being exposed to a very high current and has burnt a capacitor on the power panel.
The best thing is for you to get the appropriate screwdriver,
  1. open the cover of the phone,
  2. get a meter reader and test all the component of the board,
  3. you will discover a part that is burnt,
  4. you will see a power pack that is connected to the main board by a cable or more,
  5. disconnect the cables,
  6. replace the power pack,
  7. couple it back
  8. try to turn it on.
Take care
Jun 19, 2010 | Cyberhome CH-DVD 300 DVD Player
I have an acer aspire 47202 and it wont turn on
Here are a couple of simple things to try:
  1. try removing the battery, plugging the computer in, and starting it again. If it starts, you likely have a battery problem. To verify that it is a battery problem, reinstall the battery and try starting again.
  2. verify that the power supply is plugged in. also verify that you have the right power supply (perhaps you got the wrong one at friends ...)
  3. most power supplies have a light, do you have a light? If not, you need to buy a new power supply. You can buy a universal supply at any store that carries computers. Be sure that it has a wattage rating of at least what your old supply had. Also be sure that it has the voltage that you need. You can buy a replacement on ebay or at your manufacturers web site.
May 27, 2010 | Acer Aspire 4720 Notebook
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Nov 03, 2009 | Acer Aspire 4930-6862 Laptop
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Power supply
this is infact your video card and it can be the power supply if the burnt cable is connected to ur video card
the monitor is fine but about the burnt cable on your power supply
make sure you buy electrical tape and tape that up as soon as possible because if that burnt cable touches any part of your motherboard or anything else it will instantly fry everything which means damage everything which means ...
on the worst case scenario that has already happened
Sep 26, 2008 | Foxconn 761GXK8MB-RS Motherboard
Dell dimesion 4600 won't boot up
u try to just hold in power button shut down all way for min then back on
Feb 09, 2008 | Dell Dimension 4600 PC Desktop
Replacement Power Supply Doesn't Work
Bad ram, bad motherboard, bad video card, could be any one of a number of things.
Dec 15, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
