Question about Kenmore Ovens
Kenmore mod 42989 electric oven flashing F3 and beeping , what does this mean?
    Champion:
  • Kenmore Expert
  • 323 Answers
Posted on Feb 02, 2015
eagle338
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
  • 213 Answers
SOURCE: Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Posted on Nov 25, 2007
fridgetech
  • 473 Answers
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Posted on Jul 15, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
  • 530 Answers
SOURCE: F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Posted on Jan 04, 2009
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
What does the code f2 and f3 mean?
my ove is in selfcleaning mode and is beeping f2
Feb 16, 2012 | Kenmore 47712 / 47714 / 47719 Electric...
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Display on kenmore electric double oven flashes F3 soon after setting temperature and oven turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%%
Jul 19, 2010 | Kenmore 41389 Electric Double Oven
I have a Kenmore model #40121. I tried to use it today and after it was on for about 15 minutes at 425 degrees it started beeping and flashing F3. I turned it off and back on and about a minute later it...
Jun 04, 2010 | Kenmore 40192 / 40199 Electric Single Oven
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Nov 25, 2007 | Ovens
Ovens Logo
53 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
