Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Skaggs z trun will not start
Will not even trun over must be safty switchs
Hit kill switch going down the road, turn switch back on let out clutch but rear tie locked and want turn engine.
Hi just a thought as myself have never herd of this before.
If when you have yoused the kill switch when its at a stand still,and you put the kill switch back on and it starts,then it is quiet possible it could be a safty feature so if you came off the bike and the bike was laying on its side on the ground the back wheele wont keep spinning,just a thought as it is happening to the two bikes.
Jun 10, 2015 | Motorcycles
What happens when you trun on the tv and its cut off
Many circuits today have safty features.
If it's turning itself right back off even with the manual on button it may be a self protection against a short. Don't force it and check the outlet you have it plugged into for ground faults.
Feb 06, 2015 | Televison & Video
Switch on the door is broken, is this a safty switch?
It lets the machine know the door is closed so it is OK to start.
Jump the switch out and the machine will start even if the door is Open. no biggy.
Dec 02, 2013 | Dryers
The switch well trun on but truck will not
neutral safty switch may be the problem
Dec 01, 2012 | 1991 GMC Sonoma
Lost the remote, since the alarm was activated the car wont start even though i still have the key. everything turns on except the ignition. is there a bypass. i am stuck out of town.
1.try find on the drive's foot panel or under the steering wheel,see any switch. if you find the switch trun key on position and trun off the switch. 2. put key in passenger's door Lock it and Unlock , and put key back in the ignition try to start it. 3.turn key on position and unhood the (-) battery cable for 10 seconds , put it back and start. it.
Apr 15, 2010 | 1999 Toyota Camry Solara
Won't start
Sounds like your units cover safty switch has failed. the unit thinks the door(cover) is open(off) If you can find the switch you should be able to bypass by just shorting the wires together
May 31, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Why wont my car turn over unless i press the gas?
The break safty switch could be mixed up with the break safty switch.If the car will start without you steping on the break,the wires are mixed up in the harness or the car was put together with the break safty switch on the gas insted of the break.
May 11, 2009 | 2002 Chevrolet Impala
Ford focus will not start.
check the timing chain, it might have broke and check the oil to make sure it have enough pressure to keep pressure on the chain tentional.
Apr 17, 2009 | 2001 Ford Focus
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
22 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
