Question about Vehicle Parts & Accessories
Location of spark plugs
Chugging
    Master:
  • 710 Answers
They are screwed into the engine, above the combustion chamber.
Posted on Sep 01, 2014
Why is toyota camry 1997 have chugging problems?
If a spark plug is wet with anything other than fuel then I'd say you have a blown head gasket or cracked head.
Sep 06, 2014 | 1997 Toyota Camry
My engine is "chugging" when I reach between 40 - 50mph
use a scan tool?
got DTCs? errors.?
motto: scan first , wonder 2nd.
is chugging misfire?
Feb 26, 2014 | 2006 Jeep Grand Cherokee
2006 mazda 6 bucking when accelerating
have u checked ur spark plug leads and spark plugs it all so be ur injectors
Oct 07, 2017 | 2006 Mazda 6
My car is chugging it feels like the fuel isn't getting through. I have changed the spark plugs and about to change the fuel filter.
dont just change parts without knowing--scan car at a parts place 1st-------it cud be a failin fuel pump or pressure regulator----or an egr valve--dirty injection system-----worn plug wires------fuel system pressure test or ignition inspection may be in order
Apr 03, 2012 | 2004 Ford Focus
I have a 2007 ford freestar minivan. My van is chugging I changed the spark plugs, fuel filter, air filter, oil change and its still chugging. The engine light went on that said to change spark plug #2,...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:2
Aug 11, 2011 | 2007 Ford Freestar Limited Minivan
The car is chugging and also blowing out dark smoke
I do not know much about this vehicle but if it is diesel it sounds like you should clean and or replace air filter and or glow plugs or grid heater... if it is a gas vehicle changing the fuel filter and checking spark plug gaps and plugs and wires also the cap and rotor may have where witch will cause intermittent and weak spark so you could be getting to much fuel and running rich. also if it has a catalytic converter you may want to check if it is partially clogged and if it is have it replaced hope this helps good luck
Apr 28, 2010 | 2004 Renault 181
Recently replaced spark plugs & now the engine's chugging
the vehicle listed should not make any difference.it is possible you have wrong plugs if you did not use the proper engine size and or code.
Apr 19, 2009 | Ford F 450 Super Duty Cars & Trucks
I have 8cycl motor- is chugging, bad gas was in it?
There are 4 spark plugs in the front (#'s 2,4,6 & 8) the other 4 are located in the rear. The fuel filter is located under the car next to the rear wheel on the same side as the gas cap.
Aug 15, 2008 | 1999 Oldsmobile Aurora
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
