Question about HP Compaq ProLiant ML350 G5 Server
HP ML350 G5 can't auto bootup after shutdown
I has a APC Smart-UPS1000 which can auto shutdown the server but when come to auto bootup, it's failed. I has changed two versions of PowerChute Business Edition but still not able to fix it. Beside that, the Setup Utility for server also has been checked. Automatic Power On is enabled. Power On Delay is No delay.Please advice me on this problem.
    Novelist:
  • 79 Answers
It's divide and conquer time! First let's see if it's UPS or server related.
Try any, or all, of these Wake-On-LAN utilties to see if the server responds:
http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx
http://www.matcode.com/wol.htm
http://www.solarwinds.com/products/freetools/wake_on_lan.aspx
If it does, then there is a problem with the UPS that needs further invesigation.
If it does not, read this article from APC:
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=eIzqf7Ti&p_accessibility=0&p_lva=215&p_li=&p_faqid=2929&p_created=1057853424&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OCZwX3Byb2RzPTQ1MSZwX2NhdHM9JnBfcHY9MS40NTEmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13YWtlIG9uIGxhbg**&p_search_text=wake+on+lan
Also, if you are using a switch/router to connect the UPS to the LAN, make sure your network devices are configured to allow WOL.
Posted on Jun 19, 2009
Smart array 5300 PCI-X 64Bit/66MHz in ML350 G5 server.
it will be a controller card problem / SA5300 is 100% compitable
Jan 17, 2013 | HP Compaq ProLiant ML350 G5 Server
Server won't start HP ML350 G5
Reseat the drives, but DO NOT swap slots. Keep exact, in case of RAID configuration.
Use the Smartstart disc. It may show you the current array config.
Oct 23, 2012 | HP ProLiant ML150 G5 Server
Server won't start
I would first try reseating (removing and putting back) the SCSI card. If it is not able to reseat (built into the motherboard) you can always try to get into the BIOS diagnostic and run a system diag on the machine.
regards,
Mike
Oct 23, 2012 | HP Compaq ProLiant ML350 G5 Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Apr 08, 2009 | HP ProLiant ML350 G5 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant ML350 G5 Server Logo
1,619 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
