Question about Imperial IFS40 Deep Fryer
Dean deep fry want light
Push the pilot light and there is nothing once I put a match to it.
2 Suggested Answers
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
Gas is on pilot won t light
Hello there: The problem you mention is not that clear. The pilot won't light or the pilot lighted but won't stay on is two different problems. If the pilot won't even light or no gas coming out off the pilot when you push down the pilot button it means the pilot orfice is blocked and what it need is cleaning the pilot orfice. If the pilot light is on but goes off when you release the button then the thermopile need to be changed. Hope this can help.
Sep 23, 2010 | Frymaster Dean Kitchen Appliances - Others
Dean SM35GM pilot light low and burners won't ignite
The first thing that you need to check is the gas regulator in between the incoming gas line & the fryer. There is a plastic plug in the top, if this regulator is covered in grease then the regulator is not being vented and you will never get the burners to fire. Next is the gas valve, close to where the pilot tube comes from the valve you will find a screw about the size of a dime or smaller. WITH THE T-STAT TURNED TO THE OFF POSITION Remove that screw cap & down inside there is a plastic adjustment screw, with the unit pilot on, adjust that screw counterclockwise to the desired flame height. You won't need more than a couple of inches, now cycle the t-stat on and the burners should light. If they do not e-mail me at capt_rick1912@yahoo.com & I will walk you thru it.
captrick
Jul 10, 2009 | Dean SM20G2 Deep Fryer
Fry master
Check thermocouple if loose need to tighten or needs replacement
Aug 01, 2008 | Frymaster Dean 2424G Deep Fryer
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Imperial IFS40 Deep Fryer Logo
23 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
