Question about LaCie Computers & Internet
Lacie minimus beeping noise
Beeping and not connecting to laptop
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Lacie Desktop Hard Disk beeps when connected
No much help I can give, when an hard drive beeps it has motor error or head error, the disk hardwar is faulty, and you are not able to recover anything from the disk.
A safe data recovery can only be performed by specialized companies on a facility called clean room, where dust is completely removed from the room using a vacuum.
The data recovery using this kind of equipment does not cost less than $800.
Posted on Nov 23, 2008
Geekman
  • 32281 Answers
SOURCE: Hi My hard drive lacie minimus
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Posted on May 20, 2011
  • 3799 Answers
SOURCE: 2 tb lacie minimus hard drive stopped working
They don't work forever. As you have a power light, it may be worth taking out of the case and trying in a different case. You may be lucky.
Posted on Mar 31, 2012
Beeping noises
One thing you could try is take the drive out of the housing and place it inside your computer.
Oct 09, 2012 | LaCie 500GB Rikiki USB 30 Black
Mar 30, 2012 | LaCie Computers & Internet
My cpu won't recognize my LACIE Minimus Drive. I have no Setup Assistant and I need the info locked on the drive. What do I do?
Go download EASEUS Partition Master 5.8.1 Home Edition (free). I've found it very useful to check and often repair drives that won't mount.
Feb 26, 2012 | LaCie 1TB Minimus USB 3.0 Desktop - 301961...
Hi My hard drive lacie minimus super speed usb 3.0 1Tb is recognized by windows 7 then after a few minutes it disconnects. Donato
May 20, 2011 | LaCie 2TB MINIMUS HD USB 30 301967 USB 20...
No longer recognised by laptop
that is a common noise when your HD just failed it can be internal or external drive most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck (beeping noise) or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | LaCie (300770) 250 GB Hard Drive
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Cannot find the lacie driver on my mac
Chances are the drive is bad. Try taking it to another computer- if it doesn't work there, then the prognosis is poor. Data recovery services are available, but pricey.
Feb 05, 2009 | LaCie d2 Extreme (301033) (301033A) 160 GB...
Nov 23, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie Drive making awful noise!
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. If the drive is grinding like you say, most likely the disk is physically damaged. If this is something you experience often, maybe you should consider power conditioners. if the drive is being moved around alot, you should be gentle with it in transit. Drive enclosures, look rugged and have flashy lights and metal enclosures, but should be treated like babies. Drives are feircely sensitive. They should be padded, kept away from magnets, and treated like laptops. Hope this helps.
Sep 25, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
97 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
