Question about LG 42LD550 42 in. TV
Code I need the manufacture code to my TV
PROSCAN MANUFACTURERS CODE
There isn't a "Manufacturer's code"
Each maker of universal programmable remotes has their own set of numbers for the various codes. Procsan might be 123 in URCs code list, but cold be 987654 in Memorex.
You need to start with the make and model of universal remote that you are using. Then find the code that that brand (the remote maker) uses for the make of TV that you have.
Sep 02, 2014 | Televison & Video
NEED REMOTE CODES TO PROGRAM THIS REMOTE TO MY TV
Since you don't list your TV, I'll refer you to the manufacturer's support site: http://www.oneforall-na.com/remote.php?type=URC%203021 . The link for codes is at the bottom right (to the left is the user's manual).
The codes are limited to those for devices released 6 months or more prior to the programming of the remote. If your device is newer, you may need a new universal remote.
I hope this helps. If you indicate your TV brand, I'll check for the code in my copy of the documentation. (Sometimes, the manufacturer of the TV is not the one on the nameplate and codes for the manufacturer's own brand may work.)
Jan 15, 2011 | One For All URC-3021 Remote Control
I lost my remote and i need the four digit code so i can program my remote
The remote code for the TV depends on your remote and not on the TV. Codes are set by the remote's manufacturer. If you've lost the code list that came with your remote, you can usually find the information at the remote manufacturer's website.
Jan 08, 2011 | Emerson EWF2703 27" TV
Remote for disney princess p1300ntv television broke. i bought new "universal" remote and need code for tv. this was manufactured by starlight and the code provided in guide to new remote doesn't work on...
Try Remotes.com to buy the original remote,will never worries about codes again.This tv was manufacturer by some small company for Disney corporation,that why very hard to get the universal codes to when the tv is old.
Jun 07, 2010 | Televison & Video
HOW DO YOU FIND REMOTE CONTROL CODE FOR KENMARK TV
Each manufacturer of universal remote controls have their own codes for different brands of TV or DVD and so forth, usually a code list is provided by the manufacturer along with the remote when purchased new. Or you will need to go to the remote control manufacturer's website and look up your particular remote control to see if a list of codes is available.
Hope this helps,
James
Apr 23, 2010 | Televison & Video
Do not have manual but I need the TV code to program a remote
The TV code for a remote is set by the remote manufacturer and not by the TV manufacturer. You'll need to check the remote manufacturer's website for a list of codes. Or get a new remote control which will have the list of codes with it.
Apr 12, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Code for vizio tv
If you mean the code for this brand that you need to program a remote control, you will need to check the instructions that came with the remote. Device codes are assigned by the remote manufacturer, not by the TV maker. The code for a brand of TV won't always be the same from one remote to another. If you've lost your instructions, you can usually find them at the manufacturer's website, or get the information from your cable company if it's the cable box remote.
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
I need to know the manufacturer of the digital lifestyles tv
the manufactures name is corian usa 800-278-6334 i had this problem and it turned out that u have to use LG codes.i also had to use lg codes to code direct tv sat box
Mar 03, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Need Remot Code for Planar Plasma 19"
Best bet is to call the TV manufacturer and ask them if they have any codes that might work. Often off brand televisions are produced by a major manufacturer and may respond to standard codes not mentioned in the manual.
Feb 14, 2009 | Directv RC23 Remote Control
Manufacturer/brand of Studio Series M5400 tv
Other studio series owners suggest they are based on Samsung T.V;s not sure about the M5400.
A useful contact is the supplier of Studio series TV's in Knoxville Tel : 1-865-694-2704 contact Kelly Green Ext 116 for info
Oct 23, 2008 | Televison & Video
LG 42LD550 42 in. TV Logo
22 people viewed this question
Computer Repairing
Computer Repairing
