Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
No dial tone and base is constantly flashing red, I put the phone on the base to be charged and nothing is working. I turn it on but get no dial tone even though it says connecting. Constanly flashing red light. Can not get it to work Please help!
  • 33 Answers
Http://www.uniden.com/products/productdetail.cfm?product=ELBT595
Here is the link to the manual...
But have you tried:
1. charging the unit for 10 hours?
2. registering the handset?
Register expansion handsets to the main base
Before the expansion handset is registered, the battery pack MUST be charged for 10
hours
To register an ELX500 handset, simply place it in the main base.
To register a TCX860 handset, follow the steps below:
1) From the base, press menu/select and select S y s t e m
S e t u p menu.
2) Select R e g i s t e r H a n d s e t, and press menu/select.
3) On the handset, press and hold # until you hear a
beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
Customer Hotline at 1-800-297-1023. (Mon - Fri 7 am to 7 pm,
Sat/Sun 9 am to 5 pm, CST. Phone support is closed on holidays.)
Posted on Jun 19, 2009
New CS6124 cordless. Charging now. Why does a red 0 flash constantly in base screen? How do you turn it off? Should it be always flashing?
The message counter will blink until the first time you
press "Play" ( yes, even when there is nothing ( 0 ) to
listen to ).
Actually, this blinking serves the real function of alerting
you to the fact that power was off/interrupted and now
the clock (Time and Day) will need to be reset.
Oct 01, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Aug 11, 2008 | Uniden Lands Phones
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Second set does not work
I had this problem - just found the solution. The two charging stands aren't the same. One is a base (that plugs into the wall) and the other a charging cradle. I think that each handset needs to be placed in the base to "register" it.
So, here's what I did: place the unregistered handset in the base & both should work.
Jun 26, 2008 | GE 25952 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
453 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
