Question about Sharp LC-32SB24U 32 in. LCD TV
Wont come on
Nothing happens w/ remote or TV power button
    New Friend:
  • 38 Answers
I am assuming that you checked the power cable to the wall and the back of the TV. Most TVs have a three pin CEE22 type connector at the back for the power inlet. Sometimes this can work itself loose and come out a little disconnecting the power. Try wiggling it in until is home. You may have done that already, if that did not help it is more than likely the power supply or a fuse in the power supply is blown. Generally fuse is not accessible without taking the back cover off. Usually it is on the power supply board. Hope this helps.
Posted on May 08, 2014
3 Suggested Answers
satavlad
  • 405 Answers
SOURCE: Sharp tv doesn't turn on
Power supply/ invertor unit needs replacement.
Posted on Oct 23, 2009
SD Tech
  • 14553 Answers
SOURCE: tv trouble i need some troubleshooting help
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_7_07_49_pm.jpg
Posted on Apr 23, 2012
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Philips Televison & Video
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
IHAVE REMOTE PX-RC1 ILOSE THE CODE BOOK & TV NAME PRIMA
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
Dec 24, 2010 | Universal Remote Control MX-500 LCD Remote...
Tv wont turn on, when i press power on the remote, the red power light flashes for a second but nothing happens, is there a reset button?
reset button is usually under setup>picture>other. however your problem may be because of the lamp. If your TV is 4-5 years old you may need to change your lamp.
May 10, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Television
You need to check what micro switch are bad and replace him because for that the remote don´´t work
Aug 25, 2008 | Televison & Video
TV wont turn on
just throw it out and never buy a sony again. Sony really went down hill
May 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sharp LC-32SB24U 32 in. LCD TV Logo
97 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
