Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Frigidaire heater stays on always
I ran the dishwasher around 5:00 pm yesterday. This am the inside was still hot. I thought maybe somebody hit the botton and turned it on. At 9:00 tonight it's still hot. The dishes are hotter than normal.
  • 6,784 Answers
HI, this is a control fault. replace the control or timer module asap.
Posted on Jun 19, 2009
Car wont stay running and i thought it was feul pump or fuel filter. i replaced both and it still wont run. it will crank sometimes but cuts right off like its not getting fuel, at least thats what i was...
not value cover gasket leak out around spark plug not to inside piston. but cut right off how hot? no water in oil? or filled up piston? maybe head crack. fuel pump pumping? crack line not went eng hot. ture key on look or someone look 10lb of pressure comeing out fast.water no. antifreeze yes.
Sep 24, 2011 | 1996 Saturn SC
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
Wont' turn on
Push the "Heat Dry" button for at least 5 seconds. After that you should be able to start your dishwasher. The owner's manual I have says nothing about this, but this is a "lock panel" feature for the electronic panel design dishwashers. I just had this problem and stumbled upon a service manual online. Saved me $75.00.
May 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
DISHWASHER WONT STOP UNLESS YOU MANUALLY TURN IT OFF
Wow, I am just wondering is the water inside the dishwasher warm or hot? Or is it cold? IF it is cold it could be that the unit is trying to heat the water usually to 120 degrees.If it is hooked up to a cold water valve from your house this could be the problem. Or it is the heating element,.
Jan 05, 2009 | Dishwashers
I want to know what HO means on a frigidaire dishwasher?
it means the water is trying to heat up and it is taking longer than normal. Check your hot water heater to make sure it is heating properly. Do not use hot water in other areas at same time ..ie: washer, shower, etc. The HO will disappear once the water is heated to the proper level by the dishwasher.
Dec 31, 2008 | Frigidaire Dishwashers
Dishwasher runs for 3 hours
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Aug 14, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
FRIGIDAIRE DISHWASHER NOISE
Usually this is caused by a long spoon or something similar being hit with water and slapping the inside of the dishwasher. Also, it could be the rinse arm spinning around and hitting a tall dish or utensil in the basket below. Check to see if the arm spins all the way around before you start your load. Also, make sure all dishes can't easily move and hit the inside of the washer.
Sep 06, 2007 | Dishwashers
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
171 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
