Question about Motorola Mobility EQ5 Bluetooth Headset
I have motorola eq5 bluetooth speaker and when I try to charge it does not show any lights?
  • Official Brand Answer
  • 1,623 Answers
Try another charger.
Mark
Motorola Support
Posted on Jan 29, 2015
4 Suggested Answers
SOURCE: Car charging Bluetooth Motorola h-500
Yes, the car charger will work fine, just make sure that any time you use a car charger, remove your device when it is finished charging. If you leave your phone or bluetooth headset on the car charger, it will continually force power into it and over time reduce battery life.
Posted on Jan 21, 2008
  • 29 Answers
SOURCE: motorola blutooth
the factory defualt pin is 0000
Posted on Oct 02, 2008
casouzaj
  • 1118 Answers
SOURCE: I paired the EQ5 and my 1st generation iphone and
Make sure you establish the stereo A2DP link prior to firing up the music player on your phone. You should see some sort of indication about that link on your phone' screen (my WinMo phone shows a specific icon in the task bar). Besides, the EQ5 should be flashing in green every 6 seconds, thus indicating that the A2DP link is active.
Please, let me know if you need further informations.
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Aug 18, 2010
Problems to pair motorkr EQ5
Is the EQ5 in pairing mode? What happens when you search for the speaker?
Mark
Motorola Support
Aug 15, 2014 | Motorola Mobility Motorokr Eq5 Bluetooth...
Motorola hk250 bluetooth was put in the dryer now it won't work
The instruction set was discharged when the heat and static from the dryer caused the data to blank out. Motorola is the only source for repairs, and the chances are the Bluetooth is damaged beyond repair.
Mar 05, 2014 | Motorola Mobility HK202 Bluetooth Headset
My Ikross speakers, that I have had for about a year, have come across a problem, when I try to charge it the light will not show that it is charging, and it will not play my music either. What should I...
There are two ways of charging that speakers:
1.Through computer by USB cable.
2.Through AC Adapter.
Try to charge through both ways If in both cases the charging light is not showing than there is definitely some internal damage.
Oct 20, 2013 | iKross Solar/USB Powered Wireless...
How to change battery
You cannot change battery for that device. The battery is already placed and sealed inside. If the battery runs out, please charge it using the cable provided in the package and connect it to the power outlet.
May 23, 2013 | Motorola Mobility EQ5 Bluetooth Headset
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
I paired the EQ5 and my 1st generation iphone and it doesn't work. Audio still in the iphone and nothing in the motorola EQ5
Regards, Carlos
Sep 21, 2009 | Motorola Mobility EQ5 Bluetooth Headset
Motorola blutooth
Sep 30, 2008 | Motorola Mobility H700 Wireless Headset
Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility EQ5 Bluetooth Headset Logo
102 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
