Question about Sangean Audio Players & Recorders
Problem fm radio distortion - Sangean Audio Players & Recorders
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ยป FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
2012 cvo streetglide, loss of clarity and amp for rear speakers
Swapping the amp will have no effect on FM reception. I'm shocked that the factory would even recommend that. It's probably just a bad tuner pack in the radio. Get it replaced
Oct 08, 2012 | Harley Davidson 426290 AM/FM Radio
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Sony icf-sw77 - listening to FM if station feq is 102.0 it's distorted so have to tune to 102.05 - what's wrong here? It's the same for all FM stations AM seems fine...
Common problem and will need realignment and / or capacitor replacement. Usually on a few are bad but I recommend all to be replaced. Contact me .... poikaa(at)yahoo(dot)com
Dec 21, 2010 | Sony ICF-SW77 AM/FM/SW Radio
My ATS-909 has developed a problem. In every
I left mine under my bed for 2 years, when I turned it on it sounded very distorted. I took it apart and found the speaker to be faulty, I suspect my under floor heating may have had something to do with it. The internet suggests it's a fairly common problem. People seem to agree a sony 7600 speaker is the best replacment.
May 17, 2010 | Sangean ATS 909 AM/FM/SW Radio
The fm radio have very low quality.Noise and distortion
for the noise distortion check out the antenna if it is still good or connected
Feb 20, 2010 | Cell Phones
My sw77 has distortion on fm stations when there is bass content.
A bit late on this..... Sounds like a fault with the electrolytic capacitors. This can be repaired, please email me.... Rod (poikaa@yahoo.com )
Feb 17, 2010 | Sony ICF-SW77 AM/FM/SW Radio
No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Mar 06, 2008 | Sony XPLOD CDX-GT200 CD Player
37 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
