Question about Jandy Laars Lt 250,000 Btu Heater
Heater will go on & off every 30 second,if I use the full heat setting it will not cut out but will not heat very well some comes out of it
    Top Expert:
  • Jandy Master
  • 8,673 Answers
Check gas pressure sounds like either too small gas line or need a meter upgrade
Posted on Jun 07, 2015
Comfort-Aire REG-183 18,500 BTU Window Air Conditioner & Heater cuts on and off when not set to auto on heat only
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Bulance AC Cleaning Repair Services
Apr 04, 2015 | Comfort-Aire Heating & Cooling
Burp air bubble coolant system of dodge neon 1998
I don't believe you have air in your system. It sounds like a sticking thermostat to me. But you better figure it out quick those neon motors don't like big temp changes. Your playing with cracking or warping the head. Any way here's what i know about burping.
When you drain & refill a cooling system air is often traped in places like the heater core. If so the coolant level will appear full before it really is. To burp you need to add coolant till full or just over. Adjust the heater control to MAX heat. This will let full force of water pump to push air out of heater core. Fan speed dose not matter. Next start the motor & let it idle. As it warms up the thermostat will begin to open and close. This is when you should see fluid level drop as trapped air is pushed from system ( add fluid as needed). If this is working right you should fell quite hot air coming from heat vents. If air doesn't seem hot enough adding RPM by pulsing gas pedal should do the trick. And that should do it.
Jul 15, 2013 | Cars & Trucks
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
My heater will fire but after usually after 30 but then cuts out
could a bad high limit switch on the heat exchanger .
or most likly a flame proofing switch in burner
Dec 10, 2009 | Cozy Enclosed Front Console Heater 70,000...
Reddy heater cuts out after 30 seconds
this problem is common with this type of heater and usually means that the fan is not pushing enough air over the heat exchanger and is tripping the high limit switch.check the fan
Dec 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Jandy Laars Lt 250,000 Btu Heater Logo
46 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
