Question about Baby Lock Sewing Machines
Pattern is too large for the embroidery frame
How do i make an x follow the oncreen progress of sewing a single run quilting pattern
Pantograph - IntelliQuilter® ' Computerized Quilting ...
www.intelliquilter.com/iQpedia/Pantograph.php
A pantograph pattern is one that goes from edge to edge, over the entire quilt ...patterns - there are some interesting combinations you can use to create ... Remember to align the on-screen quilt to the quilt on the machine before you sew (use the ...Touch Realign, and follow the on-screen prompts: Find a reference point on ...
Baby Lock: Ellure
babylock.com/sewing/ellure/
With a 5" X 7" embroidery hoop and a wide variety of built-in stitches and designs, ...With 120 frame patterns and a large library of built-in designs (including 40 ... cover so you see your progress and avoid running out of thread mid-stitch. ... Baby Lock IQ Technology is what makes Baby Lock machines so smart and efficient.
[PDF]Quilt Magician Manual updated 4-23-12.indd - TinLizzie18
tinlizzie18.com/images/Quilt-Magician-Manual-updated-4-23-12.pdf
This manual will cover everything you will need to know to RUN your Quilt ... Let's getto know your Quilt Magicianâ„¢... .... pattern boxes at one time, the system will onlyrun the pat- ... You can have as many patterns as you like in each pattern box. Circle for. Start. (X) for ... button and follow the on screen steps to re-calibrate.
[PDF]SideSaddle (SS) Users Manual - The Quilting Solution
Jan 11, 2016 | Sewing Machines
Where can I get a motor for unidentified machine that will allow me to do the large embroidery patterns?
Hard to tell since you didn't provide the make and model of your machine.
Sep 25, 2015 | Sewing Machines
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
Frame skips on swf embroidery machine
ooooo ouch Can you get it to return to "home"
Dec 13, 2012 | Sewing Machines
Error Message This embroidery card cannot be used with this machine
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Feb 16, 2012 | Brother SE-270D Computerized Sewing...
Quantum XL150 embroidery patterns error messages occur with some patterns. The patterns are rejected for "too many stitches". Does this make sense to anyone?
The computer in the sewing machine can only hold so much. It's rally not very big. I expect the particular color block in your design is too "large" to fit in the computer.
If you can break the problem block(s) in half, the problem should stop.
Oct 30, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a Brother Ult 2001 and I was right in the middle of monogramming a towel using the large frame when I ran out of bobbin. I took the frame out and changed the bobbin and when I returned the frame to...
My friend just had this problem a couple weeks ago. Here's what we did. We cleaned the bobbin case with canned air lightly. We turned the machine off and disconnected the embroidery unit. Turned the machine on without the embroidery unit and ran a straight stitch. Then we turned it off, reattached the embroidery unit and touched another design of a different size. Attached the hoop without fabric just to see if it would "take it" and it did so we put the right size hoop back on and selected the design we were on originally and it worked. Some times these machines are just "touchy" and don't let you do something and after a "rest" they're ok. I hope this works for you.
Aug 24, 2010 | Brother Sewing Machines
Why can't I resize any embroidery pattern? If my machine does it, then how do I do it. Also, I bought the larger hoops for my machine and my patterns still can't be used on my machine. The machine says...
The embroidery area is programed into the embroidery machine to be a certain maximum area.
If your machine is limited to 4 x 4, then this is the maximum that can be stitched.
However, there are options. One is software to split the design into two or more sections that will fit within the limitations of the EM.
You have to stitch each section, re-hooping each time, or if your machine will accept a re-positionable hoop, this may save re-hooping.
Embird is a very popular brand that many home embroiderers used.
If you do a search, you will be able to sign up for a free trial of this software.
Feb 18, 2010 | Brother SE-270D Computerized Sewing...
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
Sewing Machines Logo
155 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
