Question about Android Apps
Hilux d4d HAVE WARNING LIGHT ON D4D POWER SEEM TO LOOSEN AND ENGINE TIMING SLOW
  • 158 Answers
SOURCE: fuel tank capacity ?
my research says 80
Posted on Aug 28, 2009
  • 277 Answers
SOURCE: Toyota diesel hilux D4D noisy engine.just
Take the Vehicle back to the Installer/Supplier, for a Free of Charge CHECK and ADVISE under New Engine Warranty. If the OIL PRESSURE is LOW, when starting up from COLD, there is a genuine fault, so do not drive any distance.
Regards,DT
  • 4793 Answers
SOURCE: d4d smoking
try wynns/redexe to clean injectors/lines,they do seem to smoke a lot though....
Posted on May 02, 2010
Testimonial: "Thanks, yes, I thought common rail should be low emmisions, less particulate!?, but I'm not sure."
1991fordf150
  • 59 Answers
SOURCE: YARIS D4D 2004 ORANGE WARNING LIGHT ON RIGHT SIDE OF DASH SYMBOL
it is probly time for it to be serviced
Posted on Jun 03, 2010
johnjohn2
  • 5763 Answers
SOURCE: Toyota hilux 3.0 D4D hard starting showing crankshaft position sensor circuit malfunction code P0335.how do i solve this...?
Check the connection to crank sensor, if wiring is good and connection is clean then replace the crank sensor and reset the code, this is the first step, the computer could be a problem also but most times its the crankshaft sensor. good day
Posted on Feb 22, 2012
Testimonial: "The connections to the sensor were bad and the hard starting is gone.Thanks JB"
Tilting backseat
glove box book
Hilux D4d Manual - lux-roc.com
www.lux-roc.com/hilux/hilux-d4d-manual.pdfToyota hilux tiger d4d sport cruiser manual pdf ' pdf owner ... Dec 05, 2014 Download Link: Pdf Download Toyota Hilux 2005-2011 Auto Repair Service Manual, ...
Oct 10, 2016 | Cars & Trucks
I own toyota hilux 2kd d4d that has a morning cold hard start, after first start all is ok
Excellent answer... short & spot on...
(except YOU didn't mention "OIL CONSUMPTION")
toyota hilux 2kd d4d... Not getting a lot of domestic... (USA)
DIESEL information... here (sorry).
From Bill Boyd here in 1994"
Toyota hilux pick up D4D has hard start in the morning but ok after the...
Jul 24, 2016 | Toyota Cars & Trucks
How to reset timing belt light on 2015 toyota d4d
  • Cliford
  • Ignition(key) off press odo button.
  • Hold odo switch ignition on for 5 seconds.
  • Switch ignition off release odo.
  • Press odo, switch ignition on and continue holding until light goes off.
  • Switch key off and check by starting vehicle.
  • The light should now be off .
  • You can also veiw links below.
    • "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota Dyna Landcrusier belt light reset
Toyota Hilux 6th generation BELT Light Reset on Denso Instrument Cluster
How to reset D4D belt light
Mar 03, 2016 | Toyota Cars & Trucks
How much engine oil do I put in a toyota hilux 2.5 d4d?
HI,the 2,5l engines takes about 5l oil,but i would start to pour about 4l and then topping it up gradually while checking the oil level.Good luck.
Make sure you are using the oil recomended by the manufacturer,and dont forget to change the oil filter and the air filter as well,that sometimes can make a big difference.
Nov 01, 2014 | Toyota Hilux
How do I replace camshafts on Toyota Hilux 3.0 d4d?
The Toyota Hilux D4D 3.0 1KDFTV is an interference engine, so if the timing is wrong then the pistons will critically damage the valves. Removing the camshafts is easy, you just need to remove the set of bearing cap bolts that fasten them, in a predetermined order. When reinstalling the camshafts you just need to ensure the peripheral stamp marks on each of the camshaft sprockets align with each other. ie Align the indented dot with its adjacent indented dot or align the highlighted indented dot with its adjacent highlighted indented dot. The bearing cap bolts will need to be fastened with a torque wrench. Then connect the timing gear pulley onto the right camshaft using a key woodruff slotted into the right camshaft groove. Always double check the timing - that the peripheral stamp marks align. Don't under tension bolts, don't over tighten bolts either.
Sep 12, 2014 | Toyota Hilux Cars & Trucks
Toyota hilux pick up D4D has a hard start in the morning but ok after the first start, kindly advise
Have a compression test done to determine the engine condition. With the hard start and oil usage it points to a worn rings and a lower compression pressure than is required.
Feb 01, 2014 | 2006 Toyota Hilux 3.0
How to connect a toyota hilux d4d denso alternator with a 4 pin plug
how to connect a toyota hilux d4d denso alternaton with a 4 pin plug
Feb 22, 2013 | Dodge Grand Caravan Cars & Trucks
D4d smoking
May 02, 2010 | 2004 Toyota Tacoma
Android Apps Logo
71 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
