Question about LG CHOCOLATE VX8500 Cellular Phone
Texting troubles when I text on my chocolate, "word" mode won't recognize frequently used words. My last one had no prob remembering words after just a few times entering them. The new one refuses to retain words not already programed.
Same here. I think on the updated one they forgot/left that part out ;-;.
Donno what to tell ya, we should get new phones >.> couse mines having issues with the touch pad and apparantly it has an invisible earphone in it.. who knew
XP
Posted on Jun 19, 2009
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
How do you add a space on the slide phone when texting..i just started to text but not sure where the space button is
On the keypad, press the # sign located on the lower right corner of the phone. This has a LOCK icon and the word SPACE in it. That is the space button when in text mode for your phone.
Oct 31, 2009 | LG CHOCOLATE VX8500 Cellular Phone
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Back button has gone?
I have the same problem but rather than redo the whole text I use the other buttons to navigate to the problem word then use the right button to go to the end of that word and redo that word only. if you are to far right to simply move up before the problem word then press right once to leave a space after the last word, then press down, this will take you to the left side of the screen, use the up key to take you to the line with the problem word. Then navigate right to the end of the problem word and use cancel to erase the word and simple retype navigate back to the end of the text and finish the text;o)
Hope this helps
Jul 06, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Can i turn off the qnotes feature
Your messages are set to 'word' and you want it set to 'alpha'. If you have your user guide this info is on page 45. Here's how to do that. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
You can enter text into your phone using the traditional method of pressing a key several times for each character, or by pressing a key once for each letter while words likely to be the one you want are chosen from a database. You can also enter symbols and numbers into a text field. In screens that require you to enter text, you see the following icons. These icons tell you which text input mode you are using: When you access a screen that requires you to enter text, you start in the mode last used.
To choose a text input mode: 1 At a screen that requires you to enter text, press m. 2 Select the text input mode you want to use. A checkmark appears next to the current mode.
Mar 15, 2009 | Motorola Mobility i560 Cellular Phone
I am trying to type text messages and my Nextel i880
When you access a screen that requires you to enter text, you start in the last mode used.
  • At the screen that requires you to enter text press the left soft key.
  • Select the text mode you want to use.
  • A check mark appears next to the current mode.
If you have any further questions review the owners manual page 62...
Motorola i880 Manual
Don't forget to vote...
Nov 30, 2008 | Motorola Mobility i880 Cellular Phone
Texting
you just have to go to settings..i think... and select entry mode and choose Abc
Jun 21, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Help!
UPGRADETHE SOFTWARE OR RESET THE PHONE.combine.yavatmal@lgmobiles.com
there, i was wondering whether you can help me. I have recently changed my sim card in my pink lg chocolate phone which was any network, i have tried to change the sim card so i could have a new mobile number but i'm having trouble using the new sim. When i try to ring it tells me its currently unavailable and it wont let me text either. I can remember my ex partner said that he had locked the last sim card to my phone and i couldnt change my number, so i was wondering whether you can tell me how to unlock my phone or the sim so i can use my phone again with my new sim card???
please help! many thanks, stacie x
Jun 19, 2008 | LG KG800 Cellular Phone
Word
click on the zero button i think......and then wen u do it will change it to different list of word u coulda typed
Nov 23, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Probs with text
Go to Settings->Other->Text Input->Personal Dictionary or Word Completion. If you have Personal Dictionary enabled, any predictive text words you've used in the past are still stored. With Word completion on, your Razr is auto-completing words from the Personal Dictionary. If you like to type the words in yourself, letter by letter, just turn these settings off. You can also want to reset your Personal Dictionary.
Jan 30, 2007 | Motorola Mobility RAZR V3
LG CHOCOLATE VX8500 Cellular Phone Logo
55 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
