Question about Royal 85X Shredder
Reverse doesn't work - Royal 85X Shredder
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
No reverse o transmission
run fault codes and look for reverse solenoid fault.
Apr 26, 2013 | 1994 Volvo 850
I got my 2001 dodge ram 1500 with the 5.9L v8 stuck in the sand at the beach. While my buddy was pulling me out from behind, I was flooring it in reverse to get out. Then my my rpm went down and the...
Need more info: is manual shift if so 4sp ,5sp or 6sp speed?
or auto w/overdrive ?
2) wont go into gear or selects reverse gear but acts
like no gear?
3) does forward gears work?
4) how's the fluids?
Jan 30, 2013 | Cars & Trucks
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
I have a 1993 mercury grand marquis and reverse doesn't work after it warms up. It does work when cold.
You can check with a local transmission shop, but usually the problem is a worn band or a weak pump. The reverse band also affects low gear.
There may also be a solenoid involved.
Sep 15, 2012 | 1993 Mercury Grand Marquis
1996 Jeep Grand Cherokee. Transmission problems. when the gear selector is in reverse, it doesn't engage in reverse. When you go to neutral, it drives forward but doesn't shift through the...
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
Jun 09, 2017 | Jeep Grand Cherokee Cars & Trucks
JAMMED SHREDDER
if you have reverse, run reverse.
if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
Apr 05, 2010 | Aurora Electronics AS662C Shredder
Transmission works fine in Drive, but reverse doesn,t work
The possiblities for your problem are: Worn out lo-reverse clutches, broken sunshell, fluid leak in the reverse apply circuit, or a worn boost valve. You are looking at having to replace or rebuild your transmission for this one.
Feb 26, 2010 | 1999 Chevrolet Silverado 1500
Royal 85X Shredder Logo
37 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
