Question about Danby Dishwashers
Danby portable dishwasher error codes - Danby Dishwashers
SOURCE: Danby portable dishwasher 1805W hose
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
Posted on Mar 01, 2009
taran_2005
  • 10515 Answers
SOURCE: danby dishwasher ddw 2406 bls-1 i
Is it 0004 or 004?
I am aware of the error 004 which states :-
Error code 004 is caused by water being present in the bottom tray of the machine. There is not supposed to be any water there but if there is any the float switch is triggered. Get rid of the water source and the problem is fixed. On my machine the leak was in the feed pipe to the upper dish tray. I replaced the feed pipe and problem solved. Water could be leaking somewhere else however so you will have to find and fix the leak.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 12, 2010
  • 3 Answers
SOURCE: Dishwasher: danby ddw1806bsl. Getting error code
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
Posted on Dec 09, 2010
mc1bean
  • 3053 Answers
SOURCE: How much Dishwashing Salt do you use in a Danby
Hello, bunny........Salt can be bought at restaurant supply houses such as cash co (united groceries)
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
mc1bean
  • 3053 Answers
SOURCE: My danby 22" countertop dishwasher wont **** water
Hello, cynthia
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
Error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go www.fitness.manualsonline.com or www. retrevo.com
God bless you
May 25, 2012 | Danby Dishwashers
What is the funnel thing that came with my dishwasher danby ddw1899WP?
The "funnel thing" is exactly what it looks like- a funnel. It's for adding the salt to the water softener located on the "floor" of the dishwasher:)
Nov 23, 2010 | Danby DDW1899WP Portable Dishwasher
Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Jun 02, 2009 | Danby DDW1805W Designer Series...
Danby portable dishwasher filter stuck
If it says just pull up then you do just that, it is likely rusted on.
Jul 18, 2017 | Danby 22 in. DDW399 Free-standing...
Danby error code 002
I spoke with Danby, and this error indicates the fact that the dishwasher is unable to fully drain. Likely causes are a kink in the hose, hose is too high on the drain pipe to drain, or, the pump motor is dying.
Seeing as mine's been mounted without fault in the same place for 2 years, I think I can tell you which one I have.
Dec 22, 2007 | Danby DDW2406 Stainless Steel Built-in...
Dishwashers Logo
18 people viewed this question
Top Danby Dishwashers Experts
Batista Saint
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
