Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Cold water keeps running and does not shut off
It first started on the permanent press cycle ,now on the regular cycle.
2 Suggested Answers
SOURCE: When I press the start button, Bosch dishwasher
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Posted on Feb 04, 2011
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Hi, I am trying to help daughter-in-law get their
Hello annp, thank you for your post! Based on the symptoms you are describing, it does sounds like a siphoning issue. Generally speaking, the drain hose should come up above the washer tub and please make sure the drain hose is not too deep in to the house drain pipe. The drain hose should only be submerged 4-8 inches into the house drain pipe. If correct, otherwise the unit might be experiencing a communication with the control board and water fill valve. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - please do not hesitate to reconnect.
Jul 31, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
Water didn't shut off
There is a part called a air-dome that is connected to the lower section of your outer drum. The part where you put your clothes in is called the inner drum.The air-dome has a small tube connected to it which travels up the drum to a level sensor in the control panel that turns off the water when the washer is full to the point water level is set.This is usually on top loaders.
Feb 06, 2010 | Kenmore 23822 Top Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Clean light flashes, don't start
Hi
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. untell the unit shuts off, then try running a cycle.After all the lights come on, stop pushing buttons and wait. The unit will start up after a couple minutes The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle.
Oct 30, 2009 | Dishwashers
Kenmore Ultrawash Quiet guard 3; can't get the clean light to turn off to be able to start cycle
Let run for a little bit. then keep pressing the start button... until the unit shuts off, then try running a cycle.
The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking there is something wrong with your heating cycle.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 01, 2009 | Kenmore Dishwashers
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Maytag washer is a bit older its a Dependable Care model 3cycle
The agitation problem is probably caused by a bad timer. Also, on the wrinkling issue, be sure that your hoses are connected right (hot to hot, cold to cold). Have found out that if they are switched, you would wash in wrong temp. Doubt that a hose would cause problems because washer wont start unless the proper amount of water is in the tub (also could be a timer problem). Good Luck!!! Jim
Sep 08, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
20 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
