SOURCE: Pink and green lines and double picture.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
SOURCE: have 46 samsung dlp that has green lines all over
Red, green, or blue retrace lines
( a quote from "Notes on the Troubleshooting and Repair of Television Sets", found at http://www.repairfaq.org/sam/tvfaq.htm#tvrgbrlin )
Where only one color is showing, suspect an incorrectly adjusted individual background/bias control or bad part on the CRT neck board for that color.
There is a slight possibility that a bad CRT may result in visible retrace lines. To eliminate this possibility:
(quote ends)
You will be greatly helped if you have a schematic for your TV set, and you may need to change some parts, clean some connector contacts and/or tweak settings inside the set, so remember the original settings before you tweak them...
Good luck
3rq8 (Triarcuate)
SOURCE: Optoma EP757 displays green image when input connected
I would suggest replacing the type of cable you are using. Changing the type of connection, such as S-Video or VGA or something other than what you are using, may resolve this issue as well. Because the splash screen comes up normal, this tells us that the issues lies not with the device but with whatever it is you are connecting it to. Comment back if this does not resolve the issue and we can move further.
Good Luck,
NOLA Tech
SOURCE: Samsung LE32R41BD - no picture, only a very dark blue screen
yes go to www.shopjimmy.com get the main board of your tv and replace it lcds usually have 2 power supply and the main one thats the problem tv repair man told me it incharged of all your inputs sound and picture but he was charging too much and the manufacturer too 149.00 shop jimmy 108 with shipping glad too help you and you r welcome and it aint no science to do it your self do it on top of your bed thats how i did mines in order to get the model number have to be real careful with the screen oh and you r welcome
