Question about liftmaster 485LM EverCharge Battery Backup
How do I change the battery on lift master pro
    Scholar:
  • 86 Answers
You can purchase a replacement battery assembly from Amazon.com for $69 (I just replaced mine). If your battery backup is mounted on top of your opener, you simply unplug the backup white plug from the back lower right corner of the opener. There are two screws holding the battery pack to the opener, one on each side which need to be removed with a Phillips screwdriver and saved to install the new battery pack. Then simply lift off the old back up power suppl (careful, it's about 8+ lbs) and install the new one, being careful to install the screws snugly and plug in the new backup. (Ceiling mounting is simply unplugging the backup unit and removing the two mounting screws from the ceiling; then reversing for the new unit) The green light will start flashing rapidly showing its charging and will do so for several days. Then it will turn solid green showing a full charge and you are set for years of backup readiness. Some words of caution: Some places sell only the replacement batteries. They do NOT have the same connections as the original batteries. So unless you are willing to purchase crimp-on connectors and do your own wiring, don't waste your money. Plus, if the electronic circuitry is bad and not just the batteries, you will waste money and time. My suggestion is buy the EverCharge as a unit and save the headaches. I did.
Posted on May 24, 2014
Lift master remote not working
It seems that the reciever part is defective, likely to surge or lighting, you have to have that module replaced.
Tony
Apr 16, 2014 | Master Heaters Lift-master Sears Craftsman...
Construction master pro screen is dim / contrast is low
It uses batteries. So if contrast is dim, it may be time to replace the batteries.
Jan 30, 2014 | Calculated Industries 4065 Construction...
Help, my Lift-Master garage door opens 2-3 ft
SOUND LIKE A BROKEN SPRING.
LOOK ABOVE THE DOOR IF THERE IS A GAP IN THE SPRING IT NEEDS TO BE REPLACED,
I DO NOT RECOMEND THIS AS A DIY JOB. THEY ARE UNDER MUCH TENSION AND CAN COST YOU FINGERS IF YOU DON'T KNOW WHATYOU ARE DOING - CALL A PRO
HOPE THIS HELPS
Apr 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain 1265 Lift-Master Professional. Does that model still exist or if not, what has replaced it. Also who carries it
I know that that is a lift-master opener. chamberlain owns lift-master. but if its a new opener your looking for try the lift-master 3800 jack shaft opener. it features a low profile design that mounts next to the door instead of on the ceiling above the door, and also incorporates a battery backup so that you will never be locked out again.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Location cmos battery fujitsu siemens amilo pro V2000
remove main cover on reverse - there will be a small (2cm) flat battery 'probably under some electrical tape' - good luck
Aug 07, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
I've forgot bios master pass
reset ur bios buy pulling the battery under the keyboard out.. for a min or two ... that will without touching any jumpers reset ur bios ...
Nov 03, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
liftmaster 485LM EverCharge Battery Backup Logo
90 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Jean DeLauche
Jean DeLauche
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
