Question about Nikon Coolpix L22 Digital Camera
The camera does not want to focus
When selecting an object to shoot, the camera will not focus
3 Suggested Answers
  • 10 Answers
SOURCE: back focus
That's not likely to be the camera but the lens. You can actually set a focussing pre-set for each lens you use on the D300. See your manual for more info.
Posted on Feb 10, 2010
akangpepen
  • 133 Answers
SOURCE: I am not able to focus my camera on most objects
have you switched the selector on the lens to A/M Mode?
Posted on Jan 04, 2011
When recording a video zoomed in how do you get the camera to focus on the object ?
Focusing is one of the most difficult parts for every digital camera. Special on the end of the moon, and if the lights are low. Every camera needs sharp contrasting backgrounds and no distracting other high contrast objects in the foreground.
Be aware when you soon in to the end of the zoom range, you can't focus on close objects. Minimum focus distance can be a few meters.
It could be you switched to silence the focus noise, what can be bad for focusing.
See what the manual is telling you about zoom and focus:
Read the manual again, and check what settings would be the best for you while shooting video with a long zoom setting.
Here is the manual:
http://downloadcenter.samsung.com/content/UM/201405/20140522111801989/WB1100F_UM_English.pdf
Jan 03, 2015 | Samsung Cameras
Tip
How to shoot a picture (generaly)
press the power of the digital camera, wait until the camera is ready
select the object , press the shutter HALF way and wait for the camera to focus and lock on the target than press the shutter all the way
the best digital camera's can focus and lock and shoot in less than a second.
the advantage of digital camera's is that you can see the result directly after taken the picture
on Apr 29, 2008 | Olympus FE-180 Digital Camera
Why when you turn the camera appears focus error
Although the manual does not have indicate a focus error, I assume you notice the camera can't focus correct.
I hope you know the camera has a focus selector, see the picture. (in the manual, page 10. For auto focus you should select C-AF (continues) or S-AF (single). If it is in manual, toy should focus yourself using the focus ring on the lens (closest to the camera)
Then to help the focus system, there is a external AF sensor. If it is dirty, then it is difficult for the camera to focus correct in a short time.
Also be aware the camera likes to have extra contrast on the focus distance and no objects in front of the subject you want to pictures, with lots of contrast.
Sometimes point to a object with a sharp contrast, on the same distance, press the shutter release button half, then reframe your picture and only then press the button complete.
when you want to shoot fast moving objects choose C-AF.
I hope this helps.
Jul 13, 2014 | Fuji Finepix S9600 Digital Camera
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
When i press the button down half way, the camera doesn't want to focus and will zoom in and out and not allow an image to be taken. What is wrong and is there anyway i can solve this issue?
The camera is trying to focus, but can't. If you're trying to shoot something very close you may need to back away from the object. Try focusing on something in the distance to see if you can get the camera to focus and shoot.
Oct 02, 2013 | Panasonic Lumix DMC-FX8 Digital Camera
Auto focus doesn't work properly all the time
It works, you have to set the camera how you want it to focus got to your menu then shooting then set
Jul 13, 2012 | Nikon D60 Digital Camera
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Focusing Difficulties
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Nikon Coolpix L22 Digital Camera Logo
47 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
