Question about Brother XL-5130 Mechanical Sewing Machine
Bobbin is stuck in bobbin case - Brother XL-5130 Mechanical Sewing Machine
dizzythevamp
  • 9 Answers
SOURCE: Needle thread getting caught in bobbin are on Brother Cs-100
I don't know if this is any help, but I would suggest taking it in to a repair store. So here is a way to find places that repair brothers machines. The place near me has done a great job both times I've gone in. Also they usually don't charge for labor, just parts. If they charge for labor it probably won't be much.
http://www.brother-usa.com/service/
Posted on Jan 06, 2009
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
  • 55 Answers
SOURCE: I have Brother LX-3125. I am using it for the
the lx 3125 has a front loading bobbin case which must be removed by pulling the latch on the bobbin case and thereby pulling the bobbin case from the shuttle.
once you have the bobbin case in your hand, let go of the latch and the bobbin will drop out of the case. you can now wind the bobbin or replace it with a wound bobbin - make sure that the bobbin thread is threaded down the slot in the case and behind the tension spring, also the bobbin should turn clockwise when you pull the bobbin thread when loking at the bobbin in the case.
scott
Posted on Jul 26, 2009
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
Threads jamming the bobbin case on elna sewing machine
Probably unevenly wound on the bobbin. Or tension needing adjusting, be careful to note where tension spring started before adjusting and do in very small increments.
Perhaps the spring has some fluff stuck on it and thread cannot slide through easily. Take out bobbin and clean
Nov 02, 2015 | Elna 2007 Mechanical Sewing Machine
While threading my bobbin, the thread slipped under the bobbin seat and got stuck. I can't dislodge it, and my bobbin won't thread. How can I fix this?
can't figure out what you mean, what bobbin seat, do you mean on the bobbin case? maybe on the post where the bobbin case goes? I guess you just have to work on getting the thread off and start over.
Jun 18, 2014 | Brother 130-stich Computerized Sewing...
Bobbin stuck in case - forgot to use the bobbin hook cover
take a small screw driver and gently lift an edge of the bobbin to lift it out
Mar 29, 2014 | Sewing Machines
The thread is being stucked in the bobbin case while sewing
Hai, I think you put the big size bobbin or bobbin thread winding is over. so you can stocked in bobbin. Otherwise you check the bobbin tension.
Mar 28, 2014 | Singer Confidence 7463 Computerized Sewing...
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Bobbin stuck
Please first remove the first needle and presserfoot. After If you're experienced with sewing on a sewing machine, don't be afraid to make changes to your bobbin tension and bobbin case. Or you gone to mechanic shop. Then you will buy a check correct case size bobbin.
Dec 19, 2013 | White Sewing 2037 Mechanical Sewing...
Help, my mom is out of town.. I sew two or three stitches and the machine stops. It sounds like it is stuck. I have taken out the bobbin and it doesn't look like anything is stuck?
Get out the manual and start with maintenance so you can be sure the bobbin area is clean.
Now start at the beginning of the manual.
Read and apply as you wind the bobbin and place it into the bobbin case.
Thread the machine - again - read and apply.
Pictures and graphics are very helpful but don't always highlight some of the important steps.
CAN"T FIND THE MANUAL -
Remove the bobbin-case and clean away any thread the may have tangled there.
Make sure the thread is tight and even on the bobbin,
If this is a vertial bobbin/metal bobbin case, the thread winds from the bobbin clockwise and then through the opening on the side of the bobbin case and under the guide just above the opening.
Lift the needle to it's highest position and then lift the lever on the bobbin-case and hold it open as you insert the bobbin-case into the shuttle.
If this is a drop-in, horizontal bobbin, the graphic on the plastic lid covering the bobbin will indicate which way the thread feeds from the bobbin and through the guides.
Replace the needle, with the flat side of the shank facing the back of the machine.
Lift the presser foot and re-thread the machine. IMPORTANT - always have the presser foot up when threading.
Hold onto the thread end, lower and raise the needle to pull up the bobbin thread, Take both thread ends under the presser foot and to the back of the machine.
Place a double layer of fabric under the presser foot. Hold onto the thread ends and lower the needle into the fabric for the first stitch.
Press on the power pedal.
Mar 14, 2010 | Kenmore Sewing Machines
Brother cs 6000 bobbin moves
Try this for me clean out the hook area under the bobbin case some times dust from thread and cloth build up under the bobbin case and it can push up the bobbin case and cause the same thing to happin.
Oct 18, 2009 | Brother CS-6000
Brother XL-5130 Mechanical Sewing Machine Logo
12 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
