Question about Canon SPEEDLITE 580EX TTL Flash
Is not working properly
When i turn on my flash is making a clicking noise, after 2 seconds it stop, then none of the functions works.
    New Friend:
  • 7 Answers
Hi Mate I had the same problem with mine and it was the zoom mechanism was stuck, I've put together a detailed tutorial on how to fix it here: http://coatesandstain.com/how-to-repair-a-canon-430ex-speedlite-zoom-function-frozen/
Posted on Jun 23, 2015
    Champion:
  • Canon Expert
  • 225 Answers
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Posted on Jan 02, 2015
2 Suggested Answers
SOURCE: SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
Posted on Dec 25, 2010
2003 malibu alarm won't stop
Well when you replaced the battery did anything else on the key fob work? Often times you have to reprogram the remote in order for it to function properly. Try getting inside the vehicle and manually lock all doors with the driver's side switch. Put the master key in the ignition switch and turn the switch to the run position but do not start it. Now push and hold the lock and unlock buttons at the same time until the locks make noise....may take 10 to 30 seconds. After you have the key fob programmed, see if the alarm will turn off with the remote. Did it work? The only way to totally turn off the alarm is with a GM Tech @ or 3 scan tool and go into body control bidirectional controlling procedures or with a very good aftermarket scanner with good bi-directional functionality.
The alarm works via the body control module on this vehicle and i am thinking it uses the PK2 system and if you do not have a properly coded key or the BCM is loosing memory, then check for any and every blown fuse and replace as needed.to start with.. If the vehicle stays running after starting then the bcm/key is reading correctly.
Jan 21, 2018 | 2003 Chevrolet Malibu
Water cooler stopped working
Compressor seized, may just need a new start relay or capacitor
Aug 07, 2012 | Haier WDNS32BW Hot Cold Water Cooler With...
Can a turn signel work for about 15 seconds and then stop? or could it be the relay?
the flasher unit is probably worn out.there is a bi-metalic metal strip that gets tired and won`t expand and contract making the clicking noise you hear when the signals are in use.it stops expanding and contracting causing the flashers to stop working.change the flasher unit but make sure you changing the one for the signal flasher and not the hazards flasher as they look the same.to know which one turn on the hazards and look for the other flasher that is not making a noise as this will be the one for the signals.
Mar 02, 2012 | Cars & Trucks
I turn on my canon mx310 and hear a constant clicking noise that lasts for 2 mintues, the alarm button flashes/blinks, and says "scanner error"... what could be causing that? and how can I fix this?
Issue: A grinding noise is heard from the device.
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
ALSO:
Make sure that the protective cover is removed from the FINE cartridge holder.
Jun 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Clicking noise under the glovebox
It may be a relay clicking. You can test the relay with an ohmmeter or multi-tester. Have you noticed any components not working?
Jul 13, 2009 | 1997 Ford Explorer AWD
Clicking noise in back freezer stopped working when i turn the dial to 0 clicking noise stops
sound like the start components are going on the nit. you will neede a three and one to make it work properly again.
Mar 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
RCA DTC210 Directv HD tuner flashes when plugged in
My DTC210 didn't want to work after being stored for awhile. Both lights were ON but there was no output.
I left it turned on and after about 2 hours it started working.
Dec 27, 2007 | RCA DTC210 DirecTV DTV Receiver
"3 second" light flashing
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
Canon SPEEDLITE 580EX TTL Flash Logo
282 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
