Question about Royal 85X Shredder
Will reverse only work on 85x royal shredder with paper jam
  • 3 Answers
SOURCE: Gears won't pull paper through
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 29, 2008
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
JayBlair
  • 328 Answers
SOURCE: CD shredder jammed with small CD pieces
If you are able to remove the top. It is easy. Usually 4 screw to remove the top. Be careful with the short cable connecting to the board. Open it up pressure clean the entire unt and especially the sensors top and bottom.
Posted on Jun 11, 2009
  • 19 Answers
SOURCE: Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
Posted on May 30, 2010
  • 1218 Answers
SOURCE: Royal 9 x cross cut shredder wont go through even two pages thick
Put some shredder oil on the paper you are shreding...shred a number of sheets with oil on them so that the oil gets down into the cutting shafts/teeth.
Posted on Aug 22, 2010
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
I have a paper jam in my shredder. How do I fix this?
Theory is that there should still be some paper sticking up that you can get a hold of.....switch the machine into reverse while trying to pull the paper back out.....if you manage that and it is still working make sure you put some shredder oil into the cutting blades and only run the machine at about 70% of its max. sheet capacity to avoid future jams and extend machine life.
Aug 30, 2010 | Royal 85X Shredder
May 25, 2010 | Royal 85X Shredder
It will not shred - the reverse works fine
UNPLUG THE MACHINE AND TRY CLEANING THE "EYES" WITH A SOFT CLOTH. IF THAT DOSN'T DO IT YOU MAY HAVE DEFECTIVE EYES OR PCB...YOU CAN CALL ROYAL FOR PARTS AT 1-800-524-0799.
May 21, 2010 | Royal 85X Shredder
Put too much paper in shredder- it jammed. I reversed the paper flow. Unit turned off. I've cleared the paper jam, but unit won't power up.
Sounds like the waste basket is not pushed all the way in. Your basket will have a piece of plastic (not in the middle, this is just a guide) probably on the right hand edge of the basket. This little piece of plastic pushes in on the safety switch. Take a flash light and look closely and you will see how this works. Take a Q-Tip and push in on this switch and see if it will power up.
Nov 15, 2009 | Royal 85X Shredder
It will reverse but it does not work in auto.
Try cleaning the "eyes" to see if they are dusty/dirty...in the middle where you insert the paper...if that dosn't fix it you probably need a new PCB...contact Royal at 1-800-524-0799 for parts assistance.
Sep 21, 2009 | Royal 85X Shredder
JAMS...DOES IT NEED OIL?
You should occassionally lubricate any x-cut shredder, just put some shredder oil on a sheet of paper ; a big "s" pattern of oil will do then shred the sheet of paper to get the oil down into the cutting shafts.
Aug 07, 2009 | Royal 85X Shredder
Royal 85X Shredder Logo
75 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
