Ir sensor location on smt-c8340 - Televison & Video
2 Suggested Answers
SOURCE: NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Posted on Jul 24, 2012
Ir extender not working with Samsung smt-c5320 cable box
Make sure the little wired sensor is covering the ir window on the cable box.
Mar 02, 2015 | Samsung Televison & Video
I need the exact location of the IR sensor on the front panel of a Motorola DCH6416 cable box.
Do this like mine sweeping. Grab the remote and put it right up to the front of the box. Press the channel up or down keys as you move the remote across the front of the box. You'll get to a point where the box responds well. Then as you go past the point the box will stop reacting so well. Home in to the point where the box responds well. That's your point for the blaster.
Sep 14, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
IR sensor location on Samsung SMT-H3270
It is to the right of the power button and is a barely visible small circle. See this helpful link below. http://samkear.com/hardware/taking-a-look-inside-the-samsung-smt-h3270-dvr
Jan 27, 2012 | Computers & Internet
How to do remove roll from sheet path?
Its malfunction of sheet path paper sensor due to dust, don't open any thing just high pressure air pump required(ex bicycle pump)blow on sheet paper path sensor located just left above of paper roll path(look black "U" shaped, blow air in it.. check it will get resolved... Reason:the IR paper sensor shell having very small path(holes both side) to run the IR beam to other side, if the dust accumulate on IR diode the rays unable to travel to other side, result malfunction of sensor, if we blow presser air on it, dust will clean & sensor will work normally.. Its not funny remedy..it will work try it...
Sep 02, 2011 | HP DESIGNJET T770 Printer
The remote control sensor on my new television does not work. I have tried several remote controls and none of them work. Is there a way I can fix this myself or do I need to wait for a technician to come...
Unfortunately, only remote can do.
If you have a philip screw driver, soldering iron and soldering lead at your home and have the guts to make the DiY, then, here is what you need to do.
Turn off the TV
On your tv, locate where the ir sensor (infrared sensor). Open the back cover of your television using the Philip Screw driver. Manage to access the small pc board where the ir sensor was attached. Examine closely the ir sensor board. Using your soldering iron and lead, try to resolder all the terminals in the ir sensor board.
After you resolder, then, return it back. And Turn on your televison.
Hope this helps!
Dec 27, 2010 | Mitsubishi Televison & Video
Where is dish network DVR VIP622 IR sensor location
Hello, Daniel Busa with Dish Network's customer service department. The ir sensor would be right below the blue green and orange light on the reciever.
Oct 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Jul 28, 2010 | Samsung Televison & Video
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Cannot locate ir sensor on dish network receiver
The IR sensor is on the front of all receivers and based on the information you provided yours is on the front right hand side. Thanks for using Fix Ya.
Sep 13, 2009 | DISH Network 322 DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
