Question about Motorola Baby Gear
Top button won't push in to go on - Motorola Baby Gear
  • Official Brand Answer
  • 3,100 Answers
Contact our Baby monitor support
Looking For Help
Mark
Motorola Support
Posted on Jan 08, 2015
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Tip
Rancilio Silvia does not heat.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
on Jan 01, 2010 | Coffee Makers & Espresso Machines
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
Lights are all on but the machine not heating so power up lights will not turn odd
Hi There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged. If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Jul 10, 2011 | Rancilio Silvia Espresso Machine
My garmin turns on just fine but it won't allow me to push any buttons. How to I fix this?
There it should be a lock switch on top of the unit that prevents you from touching buttons by accident.
May 18, 2011 | Garmin Nuvi 680 GPS Receiver
My Silvia no heat-no steam. water goes through
HI
If your lucky.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat2_bing.gif is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Jan 21, 2010 | Rancilio Silvia Espresso Machine
Does not heat
Hi
UNPLUG THE MACHINE
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Dec 20, 2009 | Rancilio Silvia Espresso Machine
I accidentally left my Silvia on overnight, with the Steam button in the "on" mode. Now the machine won't heat u at all. Help!
Hi
Nov 25, 2009 | Rancilio Silvia Espresso Machine
The steam switch was left on. Now the machine does not heat up. Help!
Nov 13, 2009 | Rancilio Silvia Espresso Machine
The water isn't heated
Hi
Jul 13, 2009 | Rancilio Silvia Espresso Machine
Baby Gear Logo
79 people viewed this question
Top Motorola Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Motorola Baby Gear Expert? Answer questions, earn points and help others
