Question about Coby TFTV3227 32 in. LCD TV
Need full screen - Coby TFTV3227 32 in. LCD TV
How i can see any video with full screen
Hello
if you are playing with media player then you need a double click on the video screen then it will be appeared on full screen. or right click on screen it will give you the option of full screen view in menu.
other wise download media player classic from internet it has same feature as windows media player.
Good Luck
Jan 24, 2011 | Computers & Internet
Cannot get full picture on the screen
Hi Mic,
Can't get full picture ?
If this is for running a dvd if it is not a
full screen version of the dvd then you
will not get it.
If it is widescreen addition you will get the
black bars at the top and bottom.
If you can't get full screen in normal mode a
few things could cause this.
One if your running from your "say" direct tv box.
You will need to try your Format button...second
button on the left of the remote.
Second you could try the restore settings on your
tv, it will restore the settings to the manufacturer's
original settings.
Keep in mind that not all tv channels are full screen.
Example: If I watch nfl gameday in HD it is full screen.
If I select the same program but, not in HD the screen
is smaller. thing it goes to a 4:3 aspect ration..
Switch back to HD and it's full screen again.
hope this helps some.
Dec 27, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My sansui flat screen is only using 50% of the screen hight after a power failure, need to know how to expand the screen view
Check if you have the full power voltage in your home. You should have a full screen if voltage is
full 110volts.
Sep 21, 2009 | Televison & Video
Need solution to get full screen
what model tv do you have? this is likely just a menu adjustment to change the format to full screen vice letterbox.
Jul 11, 2009 | Televison & Video
How do i get a full screen on my macbook of the application i am viewing?
there is no full screen exactly like there is in windows, however the green button in the upper left corner is what you want to click first. then if you need to get it bigger yet, you can drag from the box in the lower right corner to fill your screen. Most mac users don't do full screen like windows users do, but if you desire to have it, you just need to resize the window yourself. next time you open the program it will come up the size you left it.
Apr 19, 2009 | Computers & Internet
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Display not showing full screen
This is generally a driver glitch. Uninstall the video drivers from the device manager, then reboot. It will find the hardware and reinstall the drivers. Then adjust the screen resolution from display properties. This should bring your screen back to normal size.
Jul 03, 2008 | Dell Latitude C640 Notebook
Coby TFTV3227 32 in. LCD TV Logo
19 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
