Had the window unit installed. Its a european plug and i have a converter. When plugged in and reset, unit beeps and turns on but no air or heat blows. What's the problem?
SOURCE: when i first turn on
it sounds like your compressor start capacitor is to blame ..to get to it the front plastic cover needs to be removed ..remove the control panel to see the capacitor ..its round or ovel /silver/ an wires hook to the top of it ..look to see if the top is bulging or leaking fluid ..this helps the compressor /fan /start ..let me know.. an good luck../joe/
For optimum performance, the converter must be installed so exhaust flows through it in the proper direction. When laying beneath the vehicle with your feet towards the rear, the converter should be installed so the numbers stamped into it are readable.
s Random Technology Super Flow catalytic converters are designed to fit a variety of vehicles. Special adapters may be required or special air tube adapters may be required.
s If a converter with air tubes is installed on a vehicle not equipped with an air management system, both air tube fittings must be plugged.
s If a converter is installed on a vehicle with an air management system, one air tube elbow & one plug must be used.
Plug Installation
Determine which air tube fittings (if either) are to be used to make air connection in your application. (Plug the side away from the vehicle's air supply management system.) Plug the fitting(s) not used before installing converter.
1. As in Figure 1, place converter on a secure surface with air tube fittings up, being careful not to crush the converter body or heat shield.
2. Place plug(s) into airtube fitting(s). See Figure 2 for direction of plug.
3. With a hammer tap plug(s) into airtube fitting (s) until seated. The top of the plug(s) will be flush with the end(s) of the tube. See
Figure 3.
4. Crimp the end of the tube over the plug with pliers. Crimp in at least 4 places. See Figure 4.
Airtube Elbow Installation
The airtube elbow is installed on the same side of the converter as the
vehicle's air supply management system. The remaining tube should be plugged (See above). If your vehicle is not equipped with an air management system, both tubes should have been plugged.
After installing catalytic converter on the vehicle:
1. As shown in Figure 1, insert the airtube elbow into the converter's airtube fitting.
2. Position elbow in correct direction to connect air management system and secure either by welding or by using a small clamp.
3. Complete connection to the vehicle's air management system. (An airtube attachment kit may be required.)
Plug Installation
Figure 3.
