Question about Microsoft Xbox 360 Console
I am missing a piece off my printer
I have been calling for a 2 weeks and i dont seem to have the right numbers
  • 1,800 Answers
Check the support area of ur product
Posted on Jun 19, 2009
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
Tip
Paper Jams
The most common error message is the notorious paper jam message. You do a quick look and then determine there is no jam. What next? Well here is a tip that will save you possible a service call. If you find a sheet of paper that has jammed, look at it closely. It is all together as one piece or is there the tinest of pieces missing? It only takes a tiny piece to cause a jam error. Pull the print cartridge out and with a flashlight look inside the printer and especially at each roller and see if there is any hint of a piece of paper. Look closely because you can miss something. Next open the paper tray and make sure the paper guide is firm against the paper. This will cause a jam. Just drove an hour and a half this week for this issue. The paper guide was not up against the paper causing the jam. If you have a small vacuum I suggest you vacuum out the printer because there are times that the sensors can get covered with paper dust causing them to fail. Hope this helps!
on Oct 26, 2011 | HP Office Equipment & Supplies
Have a jenny crib white nov 5 2002. no model number available its missing all hardware. I would like to keep crib & assemble.
If you dont have the 2 chrome rods that are 2 feet long, you are out of luck.
They are required. Second, most Evenflos had a recall that requires the model number
to get parts for. The screws are common 10-32 and the back uses 2 extra 5/16 X 2"
bolts with wingnuts. The spring/mattress support slides in thru the metal pieces on the
foot and headboard. The foot kicker that releases the dropside is located on the back-bottom
of the dropside and it stays up with two L-braces that are notched. I really think it's time for a new
crib if you are missing these parts.
call a ParentLink Representative at 1-800-233-5921, Monday - Friday from 8 am to 5 pm.
Mar 04, 2011 | Evenflo Jenny Lind Crib
Missing Removable Drive Sleeve for Hamilton Beach food processor model #70590 where can I get one from ?
Call the company direct. I called them with the model number from my Hamilton Beach Food Processor and they shipped the item right to me the next week. The customer service number is 1-800-851-8900.
Aug 24, 2010 | Hamilton Beach Big Mouth 70590 Food...
Mechanism that reports closed door is broken, HP 6988. This is a plastic arm that engages the cartridge door and tells the printer that the door is closed.
There is a DYI fix for this that is simple to do.
Looking at the front of the printer, you will need to remove white panel in the RIGHT side. (Pull outward on the bottom of the panen and it should easily come off without damaging it.) This will reveal the small gears that are attached to the printer and the lid.
There is a small plastic piece sticking thru the side of the printer and is moved by the gears. When the printer lid is open, the plastic piece is allowed to move down towards the bottom of the printer. When the lid is closed, the plastic piece moves towards the top of the printer.
In the printer I just fixed, the plastic gear was partially broken and the part that should contact this plastic piece was missing.
The fix:
1. Use tape an tape the plastic piece to the top of the hole so it will always register the lid as being closed
2. Keep the side panel off and, when you close the lid, make sure the plastic piece is lifted and held in place by what remains of the gear.
This fix just saved my customer from having to discard over 10 ink jet cartridges - easily several hundred dollars.
While this fix is not supported by HP, it will allow you to continue to use the printer.
Oct 04, 2009 | HP DeskJet 6988 Printer
Laserjet 3700 got 59.C0 error
Figure 1: Right swing arm assemblye755e62.png
6349049.gif 1 - Part in place
2 - Part missing
i think it solves your problem
if you have any problem regarding this issue leave a feed back,we will glad to assist you
good luck
Sep 10, 2009 | HP LaserJet 3700dn Printer
Printhead missing messag
you must be change printer head or reset
Sep 05, 2009 | Kodak ESP 5 Printer
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
Phone wont list my new missed calls in the call log
I have a sony ericsson k800i and it will not tell me when I have missed a call
May 02, 2008 | Samsung Blackjack SGH-I607 Smartphone
Set Time back
To restore your settings to 2 weeks prior:
Click start > programs > accessories > system tools > restore.
To set the time back to 2 weeks earlier:
Double click the time clock at the bottom right hand corner of your screen and change the date and time.
However, if you mean you lost the printer driver, neither one of those options will find the driver. If the driver is not on your system, even doing a restore will not bring back something that is missing.
You can download the drivers for your printer here.
Dec 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Microsoft Xbox 360 Console Logo
13 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
