PrintMaster Platinum <5.0.0.15> encountered the following error:
3 Suggested Answers
SOURCE: I installed Printmaster 2011 platinum
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Posted on Dec 17, 2010
speedyfs
  • 14 Answers
SOURCE: PrintMaster 2011 Platinum <3.0.70> encountered
Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
Posted on Apr 27, 2011
My printmaster platinum 2012 will not open.
Try re-installing software. For more detail on cause. Right click on My Computer > Manage > Event Viewer > Application and check errors / warnings based on source.
Aug 26, 2012 | Broderbund PrintMaster Platinum
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Dec 17, 2010 | Broderbund PrintMaster Platinum
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
Oct 22, 2010 | Broderbund PrintMaster Platinum
Hi i am trying to install the printmaster platinum 2.0 version i have windows xp but i keep getting a java error
I installed PrintMaster Platinum 2011 and it first said that I didn't have the correct version of Java for my Mac. I downloaded the required version and was able to proceed with the installation. Did the error happen to say what version of Java is required? If so, going to the Java website and getting the newest update for Windows XP would probably allow you to go ahead and install PrintMaster.
Sep 09, 2010 | Broderbund PrintMaster Platinum
Setup has encountered an error and will quit
when were you experiencing this error message?
You might find the following steps helpful also.
clear out your C:\WINDOWS\TEMP directory (this is a storage area where files are stored before they are installed). Delete everything in this file, and your problem may be solved completely.
If this does not work, you may also need to clear out your Internet cache (temporary Internet files):
(Internet Explorer)
1. Open Internet Explorer.
2. Click on Tools -> Internet Options.
3a. In IE6 - Click on the 'Delete Files...' button on the Genral Tab
3b. In IE7 - Click on the 'Delete' button under the Browsing History section of the General Tab.
(Mozilla Firefox)
1. Open Firefox.
2. Click on Tools -> Options
3. Click on the Advanced tab -> Network Tab.
4. Click on the 'Clear Now' button under the Cache section.
- Empty your recycle bin
- Run Scandisk
1. Click Start->Programs->Accessories->System Tools
2. Select Scandisk
3. Select your hard drive. If you have more than one, you should scan each drive individually.
4. Click Standard
5. Check Automatically fix errors.
6. Click Start
- Run Defrag
2. Select Disk Defragmenter
3. Select the hard drive you wish to defrag and click ok.
Apr 20, 2010 | Broderbund PrintMaster Platinum 16
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
Problem loading Print Master gold 10 on windows vista
As I just posted on http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:Setupis_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:Setup>is_Setup.Exe FullSetup.ini from the command prompt.
Mar 24, 2009 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
