Question about RCA HD52W56 52" Rear Projection HDTV
Sound not workng and the menu board keeps popping up
The menu board keeps popping on
Philips 170s menu keeps on popping up
Sounds like a bad controller board. Board-level repair on a monitor controller board is quite difficult and bound to fail, for a number of reasons. You can look at the part number on the controller and try to locate a replacement online. Otherwise, the switch for the menu might be bad.
Mar 30, 2013 | Philips 170S7FS 17" LCD Monitor
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Jan 27, 2013 | Gateway FPD1975W 19" LCD Monitor
CAN YOU PLEASE HELP FIGURE OUT WHY MY VIEW SONIC 20INCH LCD MONITOR MENU BOX KEEPS POPPING UP AND IT IS DRIVING ME CRAZY
The problem is caused by either its main controller board or button controller board.
Well, I will try to change button board first, because it's cheap.
If you have never open up the LCD monitor, please don't open it up and try to fix!
Either you will damage the monitor when you open and/or be shocked by high voltage electricity!!
May 28, 2011 | HP 1502 LCD Monitor
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
My menu keeps popping up, and won't turn off. Even hitting the menu button on the tv won't turn it off. Soon after the menu pops up the sounds turns all the way down. The remote is not working for it...
One of two things. Most likely one of the buttons on the Tv is bad causing eratic functions. Igf so you might be able to disconnect the whole button-board. Could be the maion board in which case it's time to shop for a new TV.
May 13, 2009 | Televison & Video
Menu keep popping up
the button is shorted, unsolder the button and take it out. you can use the remote to use the menu if you want, you can also buy a new switch from radio shack.
Oct 28, 2008 | Toshiba 32A32 32" TV
Audio Menu keeps popping up
There are probably some failing components in the uPC control area, or with the keypad board on the TV sets front panel. It is also possible that there is a problem with the filtering of the distributed power through the circuit boards of the set, and there is some noise causing a false trigger of the function.
This type of fault can take some time for the tech to figure out, unless it is a published common fault with the particular model of set where they give a list of parts to change.
Jerry G.
Dec 04, 2007 | RCA F36676ET 36" TV
Menu options keeps popping up
Sounds like the button cluster has an issue...see if the menu button is stuck and if not, repair may be needed to disassemble the TV and have a look at the control section.
Jun 07, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
