Question about Coby MP300 MP3 Player
My coby mp705 4gb mp3 player randomly stopped working
My cobymp705 4gb mp3 player randomly stopped working, i tried to connect it to the computer and nothing happens. it is not on hold, and ive tried numerous times to turn it on. can any one help?
    President:
  • 828 Answers
Your MP3 player have its on system inside, this time the program itself is corrupted, you can reformat and reinstall it using its own recovery disk. and first of all install first the program of the mp3 to your PC.
Posted on Jun 19, 2009
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
My computer won't recognize the Coby MP727-8G MP3 player. I checked on the coby site for a firmware update but there is nothing available.
check wether your mp3 player is turned on when it is connected to the pc. if not turn it on. if it doesn.t work try another usb po
Dec 31, 2010 | Coby MP727 MP3 Player
Can't my mp3 player on my computer to down load
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will allow your computer to see it, & have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 01, 2010 | Coby MP-610 MP3 Player
Computer will not respond when usb is connected
Your computer should be able to fix the Coby's firmware even though you are having trouble connecting in the usual way. Please try these steps to fix your Coby MP-610 MP3 Player.
Feb 21, 2010 | Coby MP-610 MP3 Player
What does sychronizing do?
Synchronizing on most mp3 players is used for transferring one or more playlists from a computer to the player, having a connection through USB.
Creating playlists, putting mp3 data in a list with a certain name,
mp3 could be put in a specific order.
The player preserves some space of memory to remember these playlists and the playing order.
Some players support subfolders, but not having the manual for the
MP200 I'm not sure if that will work.
e.g.
MUSIC > music list 1
> music list 2
Dec 20, 2009 | SanDisk Sansa e250 MP3 Player
Cant get rid of songs on coby mp705 music player
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Nov 20, 2009 | Coby MP-705 Digital Media Player
Coby 2GB MP075-2G - memory storage problem
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Try reformatting the player and then reloading your music. To reformat, follow these steps:
Step
Connect the unit to your computer via the USB port.
Step2
Double-click the My Computer icon on your desktop, or, click your start button and choose My computer from the right side of the start menu.
Step3
Right-click the icon for the Coby player.
Step4
Choose Format from the menu that appears, and choose quick format after that.
Step5
Click Start.
Jan 25, 2009 | Coby MP-C7085 MP3 Player
Wont play Artist/Album
if the music was not odtained from a legal source then sometimes it will not sort itself out on the mp3 player, because the info on it is imcomplete, it will only show up on SHOW ALL SONGS, SONGS, or whichever the folder is that shows all the songs on the device.
good day
Jan 07, 2009 | Coby MP-705 Digital Media Player
I can't access the player
I have the same problem until I push the switch to random play.
Oct 23, 2008 | Coby MP550 MP3 Player
Coby MP300  MP3 Player  Logo
262 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
