Question about Gemmy Life-Sized Animated Santa
Ac adaptor model JOD 48u 42
Where can I get the power supply and microphone for this santa.
PVS1665 ac adaptor not working
Go to www.ebay.com Type make and model of laptop, refine search to power supply and go through the list.
Jul 05, 2012 | Computers & Internet
Need Okaya power adaptor for Protron TV Power Adaptor Model 090-02180-13Bob
Good Day Bob!
This one costs $117.99 and you can purchase it online from the link below:
http://www.powerpayless.com/ac-adapter-replace-yhi-090-02180-13-power-supply-for-protron-sova-a.html
It is an AC adapter replace YHi 090-02180-13 power supply for Protron, Sova, A
Please rate my answer.
Thank you for asking Fixya
Jul 13, 2011 | Protron Televison & Video
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Looking for a power supply for acer monitor al1714 can you help
you are looking for an AC power adaptor for your monitor, click on this link : http://www.amiline.com/AC-Adapter-Power-Supply-Acer-AL1714-AL1714b-LCD-Monitor-934271853.html but if you want, you can repair your power AC adaptor.
Dec 06, 2010 | Acer AL1716 F Monitor
Acer laptop does not work freezes with ac adaptor
well in this case the solution is to replace the mobo... what has happened is that the core voltage controller that sends uninterrupted power supply to the proc in the computer has burnt off so what can be a least expensive trial is to find the chip from the schematics of the acer laptop model and get it removed and resoldered in with hot air soldering
Jul 29, 2010 | Acer (56.04145.901) (5604145901) Power...
17MD255V Combo: LOOKING FOR AC ADAPTOR MODEL;ADPV20...
I have this power supply. Contact me at
tamburric@yahoo.com and I will ship it to you. Total cost to you will be $20.00.
Thanks in advance.
Christian Tamburri
May 18, 2010 | Philips 17MD255V Combo
Require cct dia for Jewel ac adaptor model js-12060-3k Need to replace soldered in FS1 fuse (230V 2Amp rating). Where can I obtain a replacement fuse.
Ok this is weird but ill point you the right direction.
At radioshack there should be a good supply of fuses and electronic resisters. You may find one at a TV repair shop also . Or you might get them too send you one from web purchase.
Oct 18, 2009 | Computers & Internet
I have a smartlink ESK-108 with no power supply can you tell me what voltage is required thanks?
AC/DC power adapter transformer
AD-051A 120v 13W input AC, 5v 1A output
or
JOD-41U-27 120v 100mA input AC, 5v 1A output
I have the latter and it works.
Apr 12, 2009 | Archtek America ESK-108 8x10/100 Mbps...
NEED SPECS FOR POWER SUPPLY OF DDV-1100X
have the adaptor you require....model AD2910-0207 INPUT :- 100-240VAC, 50/60HZ 0.3A OUTPUT:- 5V -2A....AC ADAPTOR hope this helps....hope you can help me i have no software (drivers) for this camera. can you assist. pete
Jan 17, 2009 | Cameras
AC Adaptor
Is the AC adaptor model AC Power Adapter: AC-3VX? If so it should fit, if not, have it replaced to where you bought it from...
Dec 09, 2007 | Fuji FinePix A500 Digital Camera
Gemmy Life-Sized Animated Santa Logo
236 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
