Question about Tylo COMBI-U7 Sauna Heater
I have a Tylo Supersport 8 - recently it would turn off after about 6 minutes and trip the fuse...I called the company where we purchased it about 9 years ago and he really wasn't much help. I had an electrician come out and he replaced the GPI fuse. He tested it several times and it still went off. I called back the company guy and he said a GPI fuse is not needed and if it were replaced with a regular fuse...it would work fine....I wish he would have mentioned this when he came out. The electrician said that they always use GPI fuses when installing sauna heaters. Your help would be appreciated.
2 Suggested Answers
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Posted on May 29, 2011
Wiring diagram for tylo ts30 single phase
Swell... Anonamous,
Take your "patience" issues to the
company (Tylo)
where they might be considered constructive...
It's just a 'TUDE here ...!!
(not helpful)
Control Panel TS (USA)
Carnac the Magnificent
Aug 23, 2014 | Tylo Deluxe 11kW Sauna Heater, w/ TS30-01...
Tracfone customer service
Are you registered on www.tracfone.com? If you are, you may have a message waiting there to update your purchased minutes. If you're not registered, I recommend you do ... very helpful. Have you tried turning your phone completely off, waiting a few minutes, then turning it back on? Calling support can be frustrating - but keep trying as a last resort. Eventually you'll get a good rep.
Aug 12, 2014 | Tracfone Wireless LG530G Pre-Paid Mobile...
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
When i push to calculate route the screen gets stuck on "calculating" and won't do anything.
You have a corrupted trip.db file.
1. connect the TND to the computer and turn the TND on.
2. go to your start menu and press on (my) computer
3. look for an external drive called intelliroute.
4. look on the drive(s) for a folder called Navi
5. double click on the Navi folder.
6. You should see a folder called User.
7. double click on the user folder.
8. You should see a file called Trip.db.
9. left click once on trip.db, then right click and delete.
10. disconnect your TND from the computer and enter a route in.
it should operate fine now.
Thanks,
Mark, Rand Lead Beta Tester
Sep 13, 2010 | Rand Mcnally TND 500 Car GPS Receiver
What fuse is for the clock in my 95 ford taurus
Clock Memory Fuse 8 and Digital Clock Fuse 6 .
A/C Compressor Clutch Fuse 17
A/C Heater Control Switch Fuse 17
A/C-Heater Mode Switch Fuse 9
Air Bag Diagnostic Monitor Fuse 7
Air Bags Fuse 5
Amplifier Fuse 11
Autolamp Dual Coil Relay Fuse 4
Backup Lamps Fuse 5
Blower Motor Speed Controller Fuse 17
Clock Memory Fuse 8
Courtesy Lamps Fuses 6 & 8
Daytime Running Lamps Fuses 5 & 10
Digital Instrument Cluster Fuses 5 & 16
EATC Blend Door Actuator [1] Fuse 17
EATC Blower Motor [1] Fuse 9
EATC Control Module [1] Fuses 5 & 16
Exterior Lamps Fuses 4 & 15
Flash-to-Pass Switch Fuse 10
Hazard Lamps Fuse 1
Heated Oxygen Sensor Fuse 5
Illuminated Entry Fuse 5
Illuminated Entry Module Fuse 8
Instrument Illumination Fuse 13
Keyless Entry Fuses 5 & 8
LCD Dimming Relay Fuse 6
Lamps On Warning Fuse 4
Lamp Out Warning Fuses 6 & 15
Liftgate Window Defrost Fuse 6
Liftgate Window Washer Fuse 6
Liftgate Window Wiper Fuse 6
Light Sensor/Amplifier Fuse 18
Low Oil Level Relay Fuse 18
Main Light Switch Fuse 6
Manual Lever Position Sensor Fuses 5 & 10
Mobile Telephone Transceiver Fuse 11
Police Accessory Relay Fuse 6
Power Antenna Fuse 11
Power Mirrors Fuse 8
Power Windows Fuse 6
Radio Fuse 11
Radio Memory Fuse 8
Rear Window Defrost Fuse 5
Redundant Radio Control Fuse 11
Shift Lock Actuator Fuse 5
Speed Control Amplifier Fuse 6
Speed Control Deactivator Switch Fuse 1
Stop Lamps Fuse 1
Transmission Control Switch Fuse 18
Turn Lamps Fuse 1
Turn Signals Fuse 5
Variable Assist Power Steering Module Fuse 5
Warning Chime Fuse 6
Warning Chime Module Fuse 18
Warning Indicators Fuse 18
Windshield Wiper Control Module Fuse 2
Windshield Wiper Motor Fuse 2.
this will help.thanks.
Feb 20, 2010 | 1995 Ford Taurus
My name is Andy Smith i am Electrical Engineer on
Hi Andy, I am Kelly and wish to at least make an attempt to help you out. I have done quite a bit of research and like you have come up with little nothing positive.
You may have to buy your own 3 phase 24DC controlled contactor and control that with a yet another relay.
At this point you may want to call Tylo direct or email them and explain your needs to see if they can help you.
Page 8 of their installtion manual shows several 3 Phase connections
http://superiorsaunas.com/storeimages/products/heaters/tylo/tylo_elec_install.pdf
Tylo contct info:
TYLö AB, Svarvaregatan 6, S-30250 Halmstad, Sweden.
Tel +46 35 10 00 80, Fax +46 35 102580. E-mail: info@tylo.se Internet: www.tylo.se
Here is the controller you may need with a 5 meter capillary tube. it does not say if it is 3 Phase and it is mecanical.
Seriously I would contact Typo directly via the contact info above and solve your problem quickly.
The link.... for the TS-30-012
http://www.saunahaus.com/Sauna-Control-Units/Sauna-control-TYLOe/TYLOe-Control-panel-TS-30-012::218.html
I do wish you the best.
Jan 26, 2010 | Tylo TS30-01 Control Panel
Heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Jan 23, 2010 | Tylo SPORT-U2 Sauna Heater 2 kW
I have purchased a used Te-2200 cash register. I want to program both the 8 and 5 percent sales tax and also change the name of the business on top. I have been trying all morning with no luck what do I...
To enable edit Company Name
1. Key turn to PGM
2. Press [5] [Subtotal]
3. Press [3][2] [Subtotal]
4. Press [4][2] [CA/AMT TEND]
5. Press [Subtotal]
6. Press [3] [Subtotal]
7. Press [2][1][2][2] [Subtotal]
8. Press [1][7][7][0][7][0][0][0][0][0] [CA/AMT TEND]
9. Press [Subtotal]
Edit ur company name
1. Press [2] [Subtotal]
2. Press [1] [3] [2] [Subtotal]
3. Input Your first line of Company Name (Max 16 Characters)
4. Press [00] [CA/Amt TEND]
5. Press [2] [3] [2] [Subtotal]
6. Input Your second line of Company Name (Max 16 Characters)
7. Press [00] [CA/Amt TEND]
8. Press [3] [3] [2] [Subtotal]
9. Input Your third line of Company Name (Max 16 Characters)
10. Press [00] [CA/Amt TEND]
11. Press [4] [3] [2] [Subtotal]
12. Input Your fourth line of Company Name (Max 16 Characters)
13. Press [00] [CA/Amt TEND]
14. Press [Subtotal]
15. Key turn back to REG1
16 Done
Oct 29, 2009 | Casio Parts Cash Register PC Desktop
The steamer does not work in my tylo combi 8 Do you have any solution to have it fixed
When was the last time you removed the rocks and cleaned out the deposits? Replace stones if they are in bad condition. This should be done once a year. also, a limit switch could have tripped and you need a service tech to reset the switch. Hope this helps and if it doesn't, call a dealer in your area. Tylo is a swedish company but there is a N. American handler http://www.airmist.com/.
Mar 21, 2009 | Tylo COMBI-U8 Heater
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Tylo COMBI-U7  Sauna Heater Logo
55 people viewed this question
Top Tylo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
