Question about HP iPAQ 310 Travel Companion GPS Receiver
IPAQ 310 Charges but wont turn on
I have a TravelMate 310. Power light comes on but it wont turn on. I noticed the screen kept ''flashing'' the last time it was on. I have had this happen twice before. I sent it in to HP and they return it stating they can not reproduce the issue. The only thing they do is flash it. You cant flash it without turning it on. Getting annoying
s4u311
  • 813 Answers
SOURCE: hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Posted on Jul 16, 2008
SOURCE: flashing lights.. when i turn power off it just does same thing
It won't help you the printer is fecked.
Posted on Sep 06, 2008
SOURCE: No blue light
I'm having the same problem for the last 2 weeks, i left my receiver in the car all day and since then it flashes once on startup and that's it, any suggestion how to reset the unit? Thanks
Posted on Sep 18, 2008
SOURCE: HP NX9600 wont power up.
The Compaq NX 9600 is rather a complicated and somewhat notorious problem child. One of HP's better ideas, and a good one when it is working.
Disconnect Power adapter from PC
Remove Battery
Hold down power on button for 30 seconds
Remove both memory modules, Stot1 and Slot2.
Re-install battery
Re-connect power adapter
Attempt to reboot.
If nothing happens the book says replace the motherboard which is very pricey.
email me @ businessimprovementgroup@msn.com and give me and update as I don't visit this site often.
Alan
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: my hp laptop wont start power light flashes on
try powering up the laptop with the battery pulled. In my case, the battery was the culprit. Probably shorted.
Posted on Apr 21, 2009
Acer Travelmate 6592G Wont Startup
do the HARD reset. Disconnect the power adapter +battery. Hold the power button by 30 seconds. And then reinstall the power adapter and battery again and test again. this will solve the problem God bless you
Apr 04, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
BLANK LIT-UP SCREEN
Can I ask, did you have any problems with the company, elaptoprepair.com?
I have read things and i wanted to make sure this was a real company with solid service and not a scam. I have read some people complaining that they did not get their laptops back and there were double charges on credit cards. I just want to know if you found this to be true and what your experience with this company was.
Alex Van Name
alexvanname@hotmail.com
310-295-8915
Feb 06, 2008 | HP iPAQ HX2415 Pocket PC
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Ipaq h4150 failed rom upgrade (white Screen)
Pull the battery out, wiat for a minute and reinstall the battery and turn it on.
May 12, 2007 | HP iPAQ H4150 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ 310 Travel Companion GPS Receiver Logo
495 people viewed this question
Top HP GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a HP GPS Expert? Answer questions, earn points and help others
