Question about Apple iPhone Smartphone
THe top two lines of the touc h screen won't work
    Problem Solver:
  • 5 Answers
Do a reset of the phone and it should work if that is software issue if not than u need to open the front pannel and use contact cleaner and wipe the board
Posted on Jun 19, 2009
Tablet manual
No, Kocaso only operate a whole replacement policy, they do not do repairs.
Aug 13, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My iPhone 4 buttons have all stopped working and I have to use assisted touch. Now I can't get that to work either; I am stuck on the screen (photo attached) and can't access anything. When you...
First
You have to Restore your iPhone via Itunes
Then check if the problem is solved
Second
If the problem hasnt been solved after Restore ,this means that the Touc Screen of your iPhone is need to be replaced with a new one
Note : The Touch Screen of the iPhone 4 is not seperated of the LCD screen,so you have to change the Whole screen (LCD and Touch Screen
Jan 26, 2013 | Cell Phones
Why when i charge my bb the touc doesnt work|?Wht can i do?/
I changed the battery and the wall charger , found out the earlier charger pin was faulty causing the screen to hang while trying to use during charging
Nov 23, 2011 | RIM BlackBerry Storm 9530 Smartphone
Just installed this lock - second one we tried (first didn't close all the way) Backlite is not working. did we oversee something?
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Jul 23, 2011 | Kwikset 907 90715 Satin Nickel SmartCode...
The touch screen is not responding. It will record using the button on camera but not able to see playback using touc screen
hi,
its just rutting problem in same models , you just need to change lance flex,change it and you find magic .
Feb 08, 2010 | Sony DCR-HC52 Mini DV Camcorder
My touc screen do not work what can i do
has to go for repair,nothing you can do manually
Oct 19, 2009 | Cell Phones
Keyboard on lap top not working
Hello there,
What I would assume in your case is that the jack is not sensing that the keyboard(external) has been unplugged. You can check if the device is working properly in Hardware manager. Assuming you are using XP right-click on My computer->click properties-> hardware manager and check under keyboards. If there's any exclamatory mark next to it then it seems there's some kind of problem with it. Right-click on the device and click on uninstall. Since most of these workstation keyboards are Microsoft PS/2, windows should automatically find and install drivers for it. If it stil doesn't work then its likely to be a hardware failure. Contact HP immediately. Let me know if you need more help.
Jan 04, 2009 | HP xb3000 (417329-001) Docking Station
My imate pdal does not accurately respong to stylus taps
enter this data on touc calibration using registry editor 2224,2024 3579,3499 861,3446 794,588 3638,654
Mar 29, 2008 | i-mate PDAL Pocket PC
My touch screen buttons stopped working, and now I cant play back or even put footage on the computer. I try to click the touc screen buttons but it doesn't work. The recording and everything works fine,...
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Sep 01, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
