Question about Nautilus Exercise & Fitness
Treadmill error code - Nautilus Exercise & Fitness
How do i fix my vfit treadmill error code showing on display error code 03?
If you wish to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Sep 25, 2016 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
LF 9100hr speed error code 28. how can it be fixed
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience.
Mar 05, 2014 | Life Fitness Lifestride 9100...
Pacemaster pro plus error code 20
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
Dec 24, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
Unlock the code on Precor treadmill?
Dear Sir:
Please try with this Reset system for Code:
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Exercise & Fitness Logo
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
